SparkJson Encoding
I am testing SparkJson to see if it will work for my application, and I have hit a snag when I attempt to set String to a JsonObject. For example, the last line of the code listed below does not compile. The compiler states that the rvalue is ambiguous whenever I use a string variable in place of string defined in double quotes.
    String gnodeMessage = "";
    StaticJsonBuffer<1024> jsonBuffer;
    JsonObject& object = jsonBuffer.createObject();
    JsonObject& gnode = object.createNestedObject("gnode");
    gnode["version"] = "1.0"; // this line compiles, and testing shows it works
    gnode["message"] = gnodeMessage; // this line will not compile
I checked the ArduinoJson documentation, and I can’t spot any syntax errors.
Citing: https://bblanchon.github.io/ArduinoJson/example/string/
// You can set a String to a JsonObject or JsonArray:
// WARNING: the content of the String will be duplicated in the JsonBuffer.
root[“sensor”] = sensor;
Can anyone tell this SparkJson noob what I am doing wrong?
This should work:
gnode["message"] = gnodeMessage.c_str();
or, if you prefer:
gnode["message"] = (const char *) gnodeMessage;
The reason is that SparkJson doesn’t know about String, and String doesn’t know what format the left side of the expression wants, so you need to tell it explicitly.
That makes perfect sense … thanks, I’ll give it a try.
Did his suggestion help you?
Yep, … worked like a charm, and I understand why. Thanks
