Hey,
i have the following function im mt code that should generate a json that will then be published in the cloud.
#include <SparkJson.h>
String generate_report(String DeviceName, int temp,int humidity, String current_time){
StaticJsonBuffer<200> jsonBuffer;
String Output;
JsonObject& root = jsonBuffer.createObject();
root["DeviceName"] = DeviceName;
root["Time"] = current_time;
JsonArray& data = root.createNestedArray("data");
data.add(temp);
data.add(humidity);
root.printTo(Serial);
return Output;
and i get the following Error Messages
lib/SparkJson/././JsonVariant.h:77:5: call of overloaded 'set(String&)' is ambiguous
temp_sensor.ino:48:24: no matching function for call to 'ArduinoJson::JsonObject::printTo(String&)'
Does anyone now what to do here? i tried to follow the instructions for the Library given on github. and Even consulted the Original documentation for the Arduino library.
The Documentation states, that i can pass an String as an argument that then gets the JSON data.
Arguments
The destination where the JSON document should be written. It can be either:
a buffer with specified size (the size includes the zero-terminator),
an implementation of Print (like Serial, EthernetClient…),
a String or an std::string.
