ArduinoJson 5.13.0 is out!
I just released a new version of ArduinoJson, a library to serialize and deserialize JSON documents.
Let’s see what’s new.
New rules for string duplications
When a program adds a string, ArduinoJson stores it differently depending on the type of the string.
In previous versions, ArduinoJson stored a pointer when the string was a plain old C string (char*, const char*, char[]), but stored a copy when the string had any other type (String, Flash strings…).
ArduinoJson 5.13 changes the rules: now, only const char* is stored with a pointer, all other string types are duplicated, which greatly simplifies our programs.
Example
Since older versions stored char[] strings with a pointer, we used to see curious behavior when adding strings in a loop. To prevent ArduinoJson for storing the same pointer (an thus the same string) several times, we had to call JsonBuffer::strdup():
JsonArray& array = jsonBuffer.createArray();
for (int i=0; i<3; i++) {
    char buffer[16];
    sprintf(buffer, "iteration %d", 0);
    array.add(jsonBuffer.strdup(buffer)); // <- need to duplicate :-(
array.printTo(Serial);
Thanks to the implicit duplication of char*, we can simplify this program to:
    char buffer[16];
    array.add(buffer); // <- implicit duplication :-)
Improvements to RawJson()
RawJson() is a special function to insert raw JSON fragments in a JsonArray or a JsonObject.
In previous versions, RawJson() only accepted const char* as an argument; now, in ArduinoJson 5.13, it also accepts String objects and Flash strings too.
But there is more: strings marked with RawJson() obey to the same duplication rules as other strings.
Here is an example:
JsonObject& root = jsonBuffer.createObject();
root["coord"] = RawJson(F("{\"lat\":48.74801,\"lon\":2.293491}"));
Bye bye strdup()
The new rules for string duplication make JsonBuffer::strdup() useless.
In ArduinoJson 5.13, JsonBuffer::strdup() is flagged as deprecated, so you’ll have a compilation warning if your program uses it.
I’ll probably remove the function in a future release, so I encourage you to update your programs.
Link to the full article
Thanks for the hard work!
