SparkCorePolledTimer
hello
am using the SparkCorePolledTimer in particle electron
i was wondering if the SparkCorePolledTimer similler to arduino one like
arduino has these actions
 // timed actions setup
      timer.setInterval(15000, RepeatTask);
      timer.setTimeout(10000, OnceOnlyTask);
      timer.setInterval(1000, DigitalClockDisplay);
      timer.setTimer(1200, TenTimesTask, 10);
so if i wanna call one time so i wont use lot of data
is there some thing like the arduino action that i can use with this library.
look in the docs at Software Timers
i did read it but am lil comfused
where do i need to place this
class CallbackClass
public:
     void onTimeout();
CallbackClass callback;
void setup ()
or loop where?
and i this case do i need the library for SparkCorePolledTimer to add it inmy code or not
i would appreciate if u show me smiple example just to explian how to use it one time call.
this is my code just to understand what i maen
#include <SparkCorePolledTimer.h>
#include <blynk.h>
// Set Blynk hertbeat interval.
// Each heartbeat uses ~90 bytes of data.
#define BLYNK_HEARTBEAT 20000
// Set Particle keep-alive ping interval.
// Each ping uses 121 bytes of data.
//#define PARTICLE_KEEPALIVE 20000
#define LOCK D0
#define UNLOCK D1
#define TRUNK D2
#define PANIC D3
#define ENGINE_START D4
#define ARM D5
#define Engine_Status D6
SparkCorePolledTimer updateTimer(5000); //Create a timer object and set it's timeout in milliseconds
void OnTimer(void); //Prototype for timer callback method
SparkCorePolledTimer updateTimer1(60000); //Create a timer object and set it's timeout in milliseconds
void WordTittle(void);
int ENGINE_STATUS=0;
  Serial.begin(9600); // See the connection status in Serial Monitor
  Blynk.begin("xxx", IPAddress(45,55,130,102), 8442);  // Here your Arduino connects to the Blynk Cloud.
 updateTimer.SetCallback(OnTimer);
 updateTimer1.SetCallback(WordTittle);
  pinMode(LOCK,OUTPUT);
  pinMode(UNLOCK,OUTPUT);
  pinMode(TRUNK,OUTPUT);
  pinMode(PANIC,OUTPUT);
  pinMode(ENGINE_START,OUTPUT);
  pinMode(ARM,OUTPUT);
  pinMode(Engine_Status,INPUT);
  digitalWrite(LOCK,HIGH);
  digitalWrite(UNLOCK,HIGH);
  digitalWrite(TRUNK,HIGH);
  digitalWrite(PANIC,HIGH);
  digitalWrite(ENGINE_START,HIGH);
  digitalWrite(ARM,HIGH);
void WordTittle(void){
     Blynk.virtualWrite(V8,"LOCK ");
    Blynk.virtualWrite(V9,"UNLOCK ");
    Blynk.virtualWrite(V10,"PANIC ");
    Blynk.virtualWrite(V11,"TRUNK ");
    Blynk.virtualWrite(V12,"ENGINE START ");
    Blynk.virtualWrite(V13,"ARM/ACTIVE ");
void OnTimer(void) {
    ENGINE_STATUS = digitalRead(Engine_Status);
    if (ENGINE_STATUS == HIGH){
        Blynk.virtualWrite(V7,"ENGINE ON ");
    else {
       Blynk.virtualWrite(V7,"ENGINE OFF ");
       Blynk.notify("Engine Off");
// Lock
BLYNK_WRITE(V0) //Function to test status from BLYNK widget to PHOTON
int state = param.asInt();
if (state ==1)
digitalWrite(LOCK,LOW);
else if (state ==0)
//Unlock
BLYNK_WRITE(V1) //Function to test status from BLYNK widget to PHOTON
if (state ==1)
digitalWrite(UNLOCK,LOW);
else if (state ==0)
//Trunk
BLYNK_WRITE(V2) //Function to test status from BLYNK widget to PHOTON
if (state ==1)
digitalWrite(TRUNK,LOW);
else if (state ==0)
//Panic
BLYNK_WRITE(V3) //Function to test status from BLYNK widget to PHOTON
if (state ==1)
digitalWrite(PANIC,LOW);
else if (state ==0)
// ENGINE_START
BLYNK_WRITE(V4) //Function to test status from BLYNK widget to PHOTON
if (state ==1)
digitalWrite(ENGINE_START,LOW);
else if (state ==0)
// ARM /active
BLYNK_WRITE(V5) //Function to test status from BLYNK widget to PHOTON
if (state ==1)
digitalWrite(ARM,LOW);
Blynk.virtualWrite(V6,"CAR ARMED ");
else if (state ==0)
Blynk.virtualWrite(V6,"CAR DISARMED ");
  Blynk.run();
  updateTimer.Update();
am useing the this lib to update every seconds for the input
and that is uasing to much data
if i wanna just run it one time when i push the button
so it wont use much data
thanks
you would re-factor your code to eliminate <SparkCorePolledTimer.h>
you don’t have to create a class, it seems.
This is the example you need to review:
// EXAMPLE
void print_every_second()
    static int count = 0;
    Serial.println(count++);
Timer timer(1000, print_every_second);
    timer.start();
