Hi! New here, and would really appreciate some help.
I’m trying to use the pulse sensor amped with the argon device, but the only library available is the PulseSensor_Spark. Is this a compatible library?
I tried running the example code, and hit a bunch of errors (ex: *** PARTICLE device not supported by this library. PLATFORM should be Core or Photon ***). The code doesn’t compile, so I was wondering if there has been an update or some sort of workaround. Is there an alternate library that I could use?
Sorry if this is a dumb question, and thanks in advance for any help!
@dombrovvski, not sure if you're still looking to get the pulse sensor working with Argon, but I was able to do by using @peekay123 's web project on this thread:
