Spark.variable() event
Hey guys,
I need to:
  1. change a LED state
  2. by clicking the bookmark in my home screen (iOS)
Well, clicking some bookmark means that I’ll be doing a HTTP GET to Spark
https://api.spark.io/v1/devices/DEVICEIDHERE/brew?access_token=ACCESSTOKENHERE
I’ve done some research, and I understood that GET’s are meant for Spark.function()
and that POST’s are for Spark.variable(). But I just need to make sure someone did the GET, nothing else.
So. Is it possible to attach another function to a Spark.variable() call? Where should I be looking at? Any other suggested solution?
If possible, I wouldn’t like to directly use TCPServer… it doens’t seem like a reliable solution.
Regards,
Gabriel
Actually, POST requests are for Spark.function() calls, and GET requests are to get Spark.variable(). Having cleared that, you could try using this code:
<html>
	<head>
	</head>
	<body>
		Function just executed.
		<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script>
		<script>
			var deviceID    = "Enter device ID here";
			var accessToken = "Enter accestoken here";
			var baseURL = "https://api.spark.io/v1/devices/";
			function doMethod(func, data) {
			  var url = baseURL + deviceID + "/" + func;
			  $.ajax({
				type: "POST",
				url: url,
				data: {
				  access_token: accessToken,
				  args: data
				dataType: "json"
			  console.log("Sent POST request.");
			doMethod("Enter function name", "optional: Enter function argument);
		</script>
	</body>
</html>
Place it on a host you can reach, and add it as a bookmark. As soon as you open it, the function will be called.
Let me know if you need any help.
Sorry for the mixup, you’re absolutely right. Thanks for the solution, but I was thinking on something more Spark-Cloud-local.
No servers, no document.ready stuff… Just a plain GET to Spark API that calls LED changing state.
Is that even possible?
Thanks again,
Gabriel
Not currently. You need to be able to make a POST request to call any spark functions.
Is this not possible with a Bookmark?
In this topic I’ve tried to explain why I think it’s not currently possible:
My solution above is a fairly simple one, as long as you can host the page somewhere. I believe github can do that for free :slight_smile:
If you’re using the local cloud, then you should be able to edit the routing and make it do whatever you’d like it to do.
Have you tried to store @Moors7 code as a .html file locally on your device an bookmark this local file?
With my MS device this works like a charm.
I also store a local HTML file, but on Dropbox. That way I can get to it from home Mac, my work PC, and my iOS device.
Thanks guys! All those ideas are working fine!
