Spark.publish() under firmware v.0.3.4
Dear Particle colleagues. I’ve been trying to use the Spark.publish() feature without success. I don’t know if there’s something wrong with my code, or if my current firmware does not support this (currently using v.0.3.4).
My intention is really simple: to send a short message from Spark and capture it in command line environment with a Ruby script (MacOSX 10.9.5).
On Spark’s side, here’s my code:
    Spark.publish("publishing_test","Hello.");
On the desktop side, here’s the code:
require 'open-uri'
webcontent = open("https://api.spark.io/v1/devices/device_number/events/publishing_test/?access_token=device_token")
content = webcontent.readlines()
puts content
But when I run the Ruby script, all I get is a blank result. I’ve tried to retrieve the published content with Curl, also without success. Any help would be appreciated.
Hi @dsaito
The Spark cloud and core firmware limit the number of published events to an average of 1 per second with a burst of up to 4 allowed. You need to add a delay after your publish command in loop; try delay(1000); for 1 second.
Hopefully on the desktop side “device_number” and “device_token” are replaced by the hex numbers for your device.
Thank you so much, bko. The code works now, but unfortunately only with curl. I may have to dig deeper into ruby url handling now.
