The docs say that the spark/device/app-hash message gets generated by the cloud “after you’ve flashed a new app…” I just got such a message in the dashboard roughly 17 hrs after last flash.Is this just sometimes delayed like this or has the cloud just flashed something to my electron? The firmware build was earlier (17 hrs ago) done locally on the develop branch. Just curious. The app-hash notice appeared at the same time and carried the same timestamp as the a publish event I expected.
I just tried your Battery Voltage + Soc code and I got the Hash along with the battery data on startup which is to be expected.
I’m letting the code run now and I will report back if I see the Hash publish event shows back up without flashing the device.
