I would like to use my Core for an external project, in a protected environment, but it will be subject to temperatures below 0 °C.
In the hardware datasheet I was only able to find the operating temperature of the wifi module.
Can you please tell me what is the operating temperature of the Core? Below and above which temperature it stops working?
Thank you
dk
Dear @harrisonhjones, thank you for your reply.
Well having a look to the bill of materials (if still current) it seems the SST25VF016B-75-4I-S2AF-ND is used which, acoring to this should be industrial.
I threw my Spark Core in the Freezer and it worked just fine. I was testing if there were startup issues after the unit was frozen, and there were not any but it did seem like it took just a tad longer to run through the startup code but not much of a difference.
