I have been trying to get my Spark Core to connect to my new router but I have been having trouble. It continually flashes Cyan when I try to connect. This is the process:
- Factory Reset (Flashes Blue)
- Connecting to the Internet (Flashes Green)
- Connecting to the Cloud (Flashes Cyan)
- Connected to the Cloud (Breathing Cyan)
But when I upload some basic code (eg. Blinking LED) I get the following happening:
- Updates Firmware (Flashes Magenta)
Then it repeats 2 and 3 over and over again. To eliminate all possibilities I tried it on a different network (my phone’s hot spot) but I got the same result. I have run the factory reset on the Spark Core and connected it via both my laptop and via the Spark App and I have gotten the same result.
I have had the core for almost 2 years with barely any problems with the hardware or the firmware and this is the first time this sort of problem has come up with me. I read about people that had similar problems, and it was concluded that there was something wrong with their Core ID. I eliminated that problem because I am able to successfully connect after running factory reset on the Core.
Any help would be greatly appreciated!
EDIT: Tried different code, same result
