Spark CLI flashing example is missing an argument [Solved]
In the CLI documents
http://docs.spark.io/cli/#running-from-source-advanced-spark-flash
the example command for the spark flashing a pre-compiled file is missing the device id arg.
What is on the page is:
spark flash --usb firmware.bin
What should be is
spark flash device_id firmware.bin
@chipmonk,
the command spark flash --usb firmware.bin is correct when you flash via USB (DFU mode).
spark flash core_id firmware.bin is also a valid command. :wink:
