Spark-cli: Always cloud flash the newest firmware
I have found myself using the spark cli more and more these days.
I have been using
spark compile *directoryname*
Then once I get the firmware bin file back, i am doing
spark flash corename firmware-xxxxx.bin
I got sick and tired of tracking down the newest firmware binary filename each time....so i used this fun little trick. it always flashes the newest firmware-xxxx.bin file in the current directory.
spark flash *corename-replaceme* `ls -tr firmware* | tail -1`
I hope that helps someone shave a few seconds off their spark dev time!
That’s so cool :slight_smile: Good to know @avidan!
Also, i edited the commands you entered to the correct ones Hope you don’t mind.
Maybe you’re not on the latest spark-cli version that’s why! perform a npm update -g spark-cli
im on the newest version of spark-cli. which command did you change? i cant tell.
i now have compile and upload in a single command.
spark cloud compile *directoryname* ; spark cloud flash *corename* `ls -tr firmware* | tail -1`
Just “compile” and not “cloud compile” as well as “flash” and not “cloud flash”
I just realised both works. That’s weird…
@Dave is that supposed to be a duplicate?
Hey @kennethlimcp,
Good question! Yes! I wanted to make sure when we updated the CLI commands that the old ones would keep working so the transition would be super smooth. :slight_smile:
The CLI documentation is still a bit lacking, I also hid a parameter in there to set the output binary filename:
spark compile . --saveTo project.bin
or
spark flash .
or
spark flash . --usb
All suggestions on improving the CLI welcome! I was using it a lot myself this weekend on a new project, and I’m eager to keep improving it. :slight_smile:
David
@avidan,
i now use this command often:
rm `ls -tr firmware_* | tail -1`;spark compile .; spark flash --usb `ls -tr firmware_* | tail -1`
This helps me clear the old firmware before compiling and flash via DFU :wink:
