In the library there are some webserver examples. The examples with the AJAX RGB are not working. (in my case)
The Hello World example is working. Has anybody tried the RGB example as well?
What library would that be? Would you mind posting the code you’ve tried?
I’ve used the webserver 0.0.1 from the sparkcore IDE and the WEB_AJAXRGB.INO
I did not changed that code, before I begin to edit things, I was testing it first.
