I have a couple of sensors on a board communicating with my photon over i2c. The photon sends the data to ubidots.
This has been working great for a few months, and is posting data to ubidots right now:
However, the code won’t build anymore. I don’t want to press “flash” because I don’t know what happened!
I was adding the relay shield library, and decided to do a quick verify, and got the errors below. I commented out what I added but the errors didn’t go away.
garden_sensors.cpp:264:20: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
garden_sensors.cpp:264:53: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
garden_sensors.cpp:281:20: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
garden_sensors.cpp:281:54: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
garden_sensors.cpp:298:20: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
garden_sensors.cpp:298:54: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
In file included from ../wiring/inc/spark_wiring.h:48:0,
from ./inc/application.h:36,
from garden_sensors.cpp:2:
In static member function 'static bool CloudClass::variable(const T&, const Types& ...) [with T = char [6]; Types = {float}]',
inlined from 'void setup()' at garden_sensors.cpp:143:38:
../wiring/inc/spark_wiring_cloud.h:81:39: error: call to 'CloudClass::_variable' declared with attribute error: Please change the variable from type `float` to `double` for use with Particle.variable().
return _variable(name, args...);
In static member function 'static bool CloudClass::variable(const T&, const Types& ...) [with T = char [9]; Types = {float}]',
inlined from 'void setup()' at garden_sensors.cpp:144:44:
In static member function 'static bool CloudClass::variable(const T&, const Types& ...) [with T = char [4]; Types = {float}]',
inlined from 'void setup()' at garden_sensors.cpp:145:35:
garden_sensors.cpp: In function 'void loop()':
garden_sensors.cpp:239:43: warning: 'data[4]' may be used uninitialized in this function [-Wmaybe-uninitialized]
data[5] = Wire.read();
garden_sensors.cpp:239:34: warning: 'data[3]' may be used uninitialized in this function [-Wmaybe-uninitialized]
garden_sensors.cpp:237:40: warning: 'data[1]' may be used uninitialized in this function [-Wmaybe-uninitialized]
data[3] = Wire.read();
garden_sensors.cpp:237:31: warning: 'data[0]' may be used uninitialized in this function [-Wmaybe-uninitialized]
make[1]: *** [../build/target/user/platform-6garden_sensors.o] Error 1
make: *** [user] Error 2
Here is my code:
//#include "RelayShield/RelayShield.h"
#include "HttpClient/HttpClient.h"
#include "Adafruit_TSL2591/Adafruit_TSL2591.h"
#include "Adafruit_TSL2591/Adafruit_Sensor.h"
#include <application.h>
#include <spark_wiring_i2c.h>
// SHT31 I2C address is 0x44(68)
#define Addr 0x44
//ubidots setup
#define VARIABLE_ID "56ede920762542261507ae9e"
#define VARIABLE_ID2 "56ee40fb76254256205bcdcf"
#define VARIABLE_ID3 "56ee46947625427931a1fba6"
#define TOKEN "edited-out"
HttpClient http;
http_header_t headers[] = {
{ "Content-Type", "application/json" },
http_request_t request;
http_response_t response;
//end ubidots setup
//lux sensor setup:
Adafruit_TSL2591 tsl = Adafruit_TSL2591(2591); // pass in a number for the sensor identifier (for your use later)
Displays some basic information on this sensor from the unified
sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
sensor_t sensor;
tsl.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" lux");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" lux");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" lux");
Serial.println("");
delay(500);
Configures the gain and integration time for the TSL2591
void configureSensor(void)
// You can change the gain on the fly, to adapt to brighter/dimmer light situations
//tsl.setGain(TSL2591_GAIN_LOW); // 1x gain (bright light)
tsl.setGain(TSL2591_GAIN_MED); // 25x gain
// tsl.setGain(TSL2591_GAIN_HIGH); // 428x gain
// Changing the integration time gives you a longer time over which to sense light
// longer timelines are slower, but are good in very low light situtations!
tsl.setTiming(TSL2591_INTEGRATIONTIME_100MS); // shortest integration time (bright light)
// tsl.setTiming(TSL2591_INTEGRATIONTIME_200MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_300MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_400MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_500MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_600MS); // longest integration time (dim light)
/* Display the gain and integration time for reference sake */
Serial.print ("Gain: ");
tsl2591Gain_t gain = tsl.getGain();
switch(gain)
case TSL2591_GAIN_LOW:
Serial.println("1x (Low)");
break;
case TSL2591_GAIN_MED:
Serial.println("25x (Medium)");
break;
case TSL2591_GAIN_HIGH:
Serial.println("428x (High)");
break;
case TSL2591_GAIN_MAX:
Serial.println("9876x (Max)");
break;
Serial.print ("Timing: ");
Serial.print((tsl.getTiming() + 1) * 100, DEC);
Serial.println(" ms");
Serial.println("");
// end lux sensor setup
// setup variables
float cTemp = 0.0, fTemp = 0.0, humidity = 0.0, tLux = 0.0;
void setup(void)
Serial.println("Starting Adafruit TSL2591 Test!");
if (tsl.begin())
Serial.println("Found a TSL2591 sensor");
else
Serial.println("No sensor found ... check your wiring?");
while (1);
/* Display some basic information on this sensor */
displaySensorDetails();
/* Configure the sensor */
configureSensor();
// Set Particle variables
Particle.variable("i2cdevice", "SHT31");
Particle.variable("cTemp", cTemp);
Particle.variable("humidity", humidity);
Particle.variable("lux", tLux);
// Initialise I2C communication as MASTER
Wire.begin();
// Initialise serial communication, set baud rate = 9600
void advancedRead(void)
// More advanced data read example. Read 32 bits with top 16 bits IR, bottom 16 bits full spectrum
// That way you can do whatever math and comparisons you want!
uint32_t lum = tsl.getFullLuminosity();
uint16_t ir, full;
ir = lum >> 16;
full = lum & 0xFFFF;
Serial.print("[ "); Serial.print(millis()); Serial.print(" ms ] ");
Serial.print("IR: "); Serial.print(ir); Serial.print(" ");
Serial.print("Full: "); Serial.print(full); Serial.print(" ");
Serial.print("Visible: "); Serial.print(full - ir); Serial.print(" ");
Serial.print("Lux: "); Serial.println(tsl.calculateLux(full, ir));
float tLux = (tsl.calculateLux(full, ir));
Particle.publish("Lux: ", String(tLux));
delay(300);
void loop(void)
// displaySensorDetails();
// lux calculations
uint16_t ir, full;
ir = lum >> 16;
delay(300);
//advancedRead();
// Start I2C Transmission
Wire.beginTransmission(Addr);
// Send 16-bit command byte
Wire.write(0x2C);
Wire.write(0x06);
// Stop I2C transmission
Wire.endTransmission();
delay(500);
unsigned int data[6];
// Stop I2C Transmission
// Request 6 bytes of data from the device
Wire.requestFrom(Addr,6);
// Read 6 bytes of data
// temp msb, temp lsb, crc, hum msb, hum lsb, crc
if(Wire.available() == 6)
data[0] = Wire.read();
data[1] = Wire.read();
data[2] = Wire.read();
data[4] = Wire.read();
delay(300);
// Convert the data
float cTemp = ((((data[0] * 256.0) + data[1]) * 175.72) / 65536.0) - 46.85;
float fTemp = (cTemp * 1.8) + 32;
float humidity = ((((data[3] * 256.0) + data[4]) * 125) / 65535.0) - 6;
// Output data to dashboard
//Particle.publish("Lux: ", String(tLux));
Particle.publish("Temperature in Celsius: ", String(cTemp));
delay(300);
Particle.publish("Temperature in Fahrenheit: ", String(fTemp));
delay(300);
Particle.publish("Relative Humidity: ", String(humidity));
delay(300);
delay(300);
//ubidots
delay(100);
// setting ubidots request path 1
request.hostname = "things.ubidots.com";
request.port = 80;
request.path = "/api/v1.6/variables/"VARIABLE_ID"/values?token="TOKEN;
// sending variable 1 to ubidots
Serial.println("Sending data ...");
request.body = "{\"value\":" + String(cTemp) + "}";
// Ubidots Variable 1 Post request
http.post(request, response, headers);
Serial.println(response.status);
Serial.println(response.body);
delay(100);
// setting ubidots request path 2
request.port = 80;
request.path = "/api/v1.6/variables/"VARIABLE_ID2"/values?token="TOKEN;
// sending varible 2 to ubidots
request.body = "{\"value\":" + String(humidity) + "}";
// Ubidots variable 2 Post request
delay(100);
Really strange because this code flashed just fine just a couple months ago!
(e.g. look here
