[Solved] Spark core hard resets before completing tcp connection
I have the same problem in two different cases, my problem:
complete reset after trying to connect with a tcp client.
The two cases:
  1. in the main loop I try to do a get request using the tcp client every 5 seconds until I get the information I need from the server then I turn the wifi off. I’m not using delays in my code just checking how long passed with millis() to make sure 5 seconds passed before I try again.
2.After turning Wifi.on and waiting for connection meaning: while (WiFi.status() != WIFI_ON) { SPARK_WLAN_Loop() ; }
I try to do another get request to inform the server I’m done, again the core randomly crashes on me, and resets, usually I see blinking red lights before the full reset.
Its very crucial for me to report to the server without fault so I’ll implement a write to the eeprom and I’ll check if I have something there every time the core starts and report.
Anyone encountered something similar or have other workarounds to suggest?
Thank you!
Including the code, although its really a work in progress.
#include "flashee-eeprom/flashee-eeprom.h"
#include "neopixel/neopixel.h"
using namespace Flashee;
//Wifi & Http
TCPClient client;
char roshenShay[] = "rosenshay.com";
//Change object Id here CRUDE! TODO::change it
char urlGetDuration[] = "****?obj=11";
char urlCloseTask[] = "*****close_task.php?";
long httpGetTimer;
#define GETREQUESTCHECKDELAY 5000
// NeoPixel
#define NEOPIXEL_PIN D2
#define NUMOFPIXELS 24
#define NEOPIXEL_TYPE WS2812B
#define RED strip.Color(10, 0, 0)
#define GREEN strip.Color(0, 10, 0)
#define BLUE strip.Color(0, 0, 10)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMOFPIXELS, NEOPIXEL_PIN, NEOPIXEL_TYPE);
//Array to keep current color of each led on the strip
uint32_t leds[NUMOFPIXELS] ;
long currentTaskDuration;
long startTaskTime;
//Fading Led Variables
int colorFadeLevel = 10;
int LastLedToFade = 0;
boolean isRed = false;
boolean isLightGoingUp  = true;
float calc ;
int ledLightIntensity = 5;
int fadeLevelArray[] = {10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1};
long fadeLedCheck = 0;
//End Fading
#define TIMEFRAME 300000
#define TIMECONSTRAINTBETWEENBUTTONCLICKS 10000
int numberOfLedsOn  = NUMOFPIXELS;
//Button Variables
int button = D0;
long timeFromLastClick = 0;
//State variables
long taskScheduledDuration;
long endFillEffectCheck = 0;
int taskId;
int state = 0 ;
bool taskStarted = false;
bool DEBUG = true;
//object that will help in saving to eeprom
FlashDevice* flash;
  state = 0;
  if (DEBUG){
  httpGetTimer = millis();
  fillStrip(BLUE, NUMOFPIXELS);
  taskScheduledDuration = 0;
  pinMode(button, INPUT);
  flash = Devices::createAddressErase();
bool once = true;
  if (once) {
    //DEBUG!! REMOVE
    //while (!Serial.available()) SPARK_WLAN_Loop();
    char buf[50];
    flash->read(buf, 0, 50);
    debug("eeprom:");
    debug(String(buf));
    once = false;
  switch (state)
      //Waiting for Duration and debug flag (not yet implemented) from server
    case 0: {
        char args[] = " ";
        getRequestWithDelay(roshenShay, urlGetDuration, args);
        String result = checkForHttpResult();
        if (result != "") {
          getDurationFromHttpResult(result);
          getTaskIDFromHttpResult(result);
        if (taskScheduledDuration != 0) {
          state = 1;
          WiFi.off();
          while (WiFi.status() != WIFI_OFF) {
            SPARK_WLAN_Loop();    // run backgound task so wifi can turn off
          fillStrip(0, NUMOFPIXELS);
          refreshStrip();
      break;
      //standby until first button click
    case 1: {
        debug("WaitForFirstClick");
        //go dark and wait for first click
        if (checkButtonState()) {
          state = 2;
      break;
      //Leds Count down until second button click, TODO:: or 5 minutes passed(not yet implemented)
    case 2: {
        debug("starting Led");
        taskCountDown();
          state = 3;
          //debug
          flash->writeString("testi", 0);
          once = true;
      break;
    case 3: {
        if (finishedBlueEffect()) {
          state = 4;
      break;
    case 4: {
        debug("Going out of sleep");
        WiFi.on();
          SPARK_WLAN_Loop() ;   // run backgound task so wifi can turn on
        state = 5;
      break;
      //Wait for connection to be made
    case 5: {
        String taskIdString = String(taskId);
        String durationString = String(currentTaskDuration);
        String argsString = "task=" + taskIdString + "&duration=" + durationString;
        char charBuf[argsString.length() + 1];
        argsString.toCharArray(charBuf, argsString.length() + 1) ;
        flash->writeString(charBuf, 0);
        debug(charBuf);
        //TODO: Make sure connection does not fail and returns success, replace this 3 iterations with server response verification
        getRequestWithDelay(roshenShay, urlCloseTask, charBuf);
        if (checkSuccessCloseTask(result)) {
          state = 6;
          debug(result);
      break;
      //check that returned OK meaning we finished the close task request
      //Go to sleep till next time
    case 6: {
        debug("going to deep sleep");
        refreshStrip();
        Spark.sleep(SLEEP_MODE_DEEP, 20);
      break;
  refreshStrip();
String sendGetRequest(const char * server, const char * url, const char * args)
  String result = "";
  if (client.connect(server, 80)) {
    debug("connected");
    client.print("GET ");
    client.print(url);
    if (sizeof(args) > 3) {
      client.print(args);
    client.println(" HTTP/1.0");
    client.println("Connection: close");
    client.print("Host: ");
    client.println(server);
    client.println("Accept: text/html, text/plain");
    client.println();
    result = "connected";
  }  else
    debug("connection failed");
    result = "failed";
  return result;
String getRequestWithDelay(char rosenShay[], char url[], char args[]) {
  if (millis() - httpGetTimer > GETREQUESTCHECKDELAY ) {
    return sendGetRequest(rosenShay, url, args);
  else return "false";
void getDurationFromHttpResult(String result) {
  if (checkForValidResult(result)) {
    //Get only the content without the headers
    String resultContent = result.substring(result.indexOf("\r\n\r\n"));
    //Get the duration
    String durationString = resultContent.substring(resultContent.indexOf(":") + 1);
    taskScheduledDuration = stringToLong(durationString);
    debug("  Duration : ");
    debug(taskScheduledDuration);
void getTaskIDFromHttpResult(String result) {
    //Get the taskid
    String taskIdString = resultContent.substring(0, resultContent.indexOf(":"));
    taskId = (int)stringToLong(taskIdString);
    debug("  taskId : ");
    debug(taskId);
long stringToLong(String str) {
  char longbuf[32]; // make this at least big enough for the whole string
  cleanChars(longbuf, 32);
  str.toCharArray(longbuf, sizeof(longbuf));
  return atol(longbuf);
void cleanChars(char* charArray, int length) {
  //make sure theres no garbage in the memory
  for (int j = 0; j < length; j++) {
    charArray[j] = *"";
bool checkForValidResult(String result) {
  if (result.indexOf("\r\n\r\n") != -1) {
    if (result.indexOf(":") > 0 ) {
      return true;
    } else
      return false;
  } else
    return false;
String checkForHttpResult() {
  String result = "";
  bool stopClient = false;
  while (client.available())
    char letter = client.read();
    //TODO:: Crude way of adding char to string, this was a quick bug fix, replace this code!
    result += " ";
    result[result.length() - 1] = letter;
  if (!client.connected()) {
    client.flush();
    client.stop();
  return result;
bool checkSuccessCloseTask(String result) {
  if (result.length() > 0) {
    if (result.indexOf("OK") != -1) {
      return true;
  return false;
bool checkButtonState() {
  if (millis() - timeFromLastClick > TIMECONSTRAINTBETWEENBUTTONCLICKS ) {
    if (digitalRead(button) == 1) {
      timeFromLastClick = millis();
      return true;
    } else return false;
  else return false;
void fillStrip(uint32_t color, int numberOfOnPixels) {
  //Fill with green
  for (int i = 0; i < NUMOFPIXELS; i++) {
    if (i >= numberOfOnPixels) {
      leds[i] = strip.Color(0, 0, 0);
    else {
      leds[i] = color;
void refreshStrip() {
  //Updates all the leds on the strip
  for (int i = 0; i < strip.numPixels(); i++) {
    strip.setPixelColor(i, leds[i]);
  strip.show();
void fadeLedEffect(int ledNumber, uint32_t color) {
  if ( millis() - fadeLedCheck > 120) {
    fadeLedCheck = millis();
    //Fade the last led:
    if (isLightGoingUp) {
      colorFadeLevel++;
    else {
      colorFadeLevel--;
    if (colorFadeLevel >=  10) {
      isLightGoingUp = false;
    else if (colorFadeLevel <= 0) {
  if (ledNumber > 24) {
    debug("Error in fadeLedEffect:led number larger then 24");
    ledNumber = 24;
  } else  if (ledNumber < 0) {
    debug("Error in fadeLedEffect:led number smaller then 0");
    ledNumber = 0;
  if (color == GREEN) {
    leds[ledNumber] = GREEN * colorFadeLevel;
  } else if (color == RED) {
    leds[ledNumber] = RED * colorFadeLevel;
  } else if (color == BLUE) {
    leds[ledNumber] = BLUE * colorFadeLevel;
void taskCountDown(void) {
  if (!taskStarted) {
    currentTaskDuration = 0;
    startTaskTime = millis();
    taskStarted = true;
  currentTaskDuration = millis() - startTaskTime;
  //prevent led blink from the first led
  if (currentTaskDuration == 0) {
    currentTaskDuration++;
  long timeLeft = taskScheduledDuration - currentTaskDuration;
  debug(String(timeLeft));
  //TODO::  FIX TASKS LONGER THEN TIMEFRAME HALTS THE PROGRAM
  calc = (float)timeLeft / (float)TIMEFRAME;
  if (calc > 1) {
    calc = 1;
  debug(String(calc));
  numberOfLedsOn  =  (int)(abs(calc * NUMOFPIXELS));
  //first led is 0 in the led array
  numberOfLedsOn --;
  if (numberOfLedsOn > 24) {
    numberOfLedsOn = 24;
  if (numberOfLedsOn < 0) {
    numberOfLedsOn = 0;
  //If we moved to another lead reset fade.
  if (LastLedToFade != numberOfLedsOn) {
  LastLedToFade = numberOfLedsOn;
  if ( timeLeft > 0) {
    fillStrip(GREEN * ledLightIntensity, numberOfLedsOn  );
    isRed = false;
  else {
    fillStrip(RED * ledLightIntensity, numberOfLedsOn);
    isRed = true;
  if (!isRed) {
    fadeLedEffect(LastLedToFade, GREEN);
  else {
    fadeLedEffect(LastLedToFade, RED);
bool finishedBlueEffect() {
  if (millis() - endFillEffectCheck > 23) {
    endFillEffectCheck = millis();
    numberOfLedsOn++;
    if ( numberOfLedsOn <= 24) {
      fillStrip(BLUE, numberOfLedsOn);
    else if ( numberOfLedsOn <= 48) {
      fillStrip(BLUE, 48 - numberOfLedsOn);
    else {
      fadeLedEffect(0, BLUE);
      return true;
  return false;
void debug(String str) {
  if (DEBUG) {
    Serial.println(str);
void debug(long str) {
  if (DEBUG) {
void debug(int str) {
  if (DEBUG) {
Posting working code if anyone would ever need this,
With eeprom as backup to tcp failure, but it doesn’t fail now, I had some issues with char arrays and strings, that threw everything off, I’m currently working on removing the use of the String class entrily.
//Wifi & Http
TCPClient client;
char roshenShay[] = "**";
char urlGetDuration[] = "**get_blink.php?obj=11";
char urlCloseTask[] = "**close_task.php?";
long httpGetTimer;
// NeoPixel
#define NUMOFPIXELS 20
long startTaskTime;
float calc ;
//End Fading
//Button Variables
int button = D0;
//State variables
int taskId;
int state = 0 ;
bool DEBUG = true;
long statePrintDelay = millis();
  //state = Checking to see if eeprom holds previous duration
  state = 777;
bool once = true;
  switch (state)
    case 777:{
        //DEBUG!! REMOVE
        fillStrip(GREEN, NUMOFPIXELS);
        refreshStrip();
        // END OF DEBUG
        String arguments = readFromEEP();
        debug("eeprom:");
        debug(arguments);
        if(arguments.indexOf("duration") != -1){
         char charBuf[arguments.length() + 1];
         arguments.toCharArray(charBuf,arguments.length() + 1);
        //There is something in the eeprom
        if (checkSuccessCloseTask(checkForHttpResult())) {
          state = 0;
          debug("arguments from eeprom:");
          debug(arguments);
          debug("Finished sending request that was saved from eeprom");
          //Clean the eep
          saveToEEP(String(' '),1);
        }else{
            //Nothing in the eeprom move along;
            state = 0;
      break;
    case 0: {
        refreshStrip();
        char args[] = " ";
        if (result != "") {
          state = 1;
          WiFi.off();
          refreshStrip();
      break;
    case 1: {
          state = 2;
      break;
    case 2: {
        taskCountDown();
          state = 3;
      break;
    case 3: {
          state = 4;
      break;
    case 4: {
        WiFi.on();
        state = 5;
      break;
    case 5: {
        refreshStrip();
        debug("Case 5: before");
        int argsStringLength = argsString.length() + 1;
        //Length + 1 for the end char
        char charBuf[argsStringLength];
        debug("Case 5: 1");
        argsString.toCharArray(charBuf,argsStringLength);
        debug("Case 5: 1.1");
        saveToEEP(argsString, argsString.length());
        debug("Case 5: 1.2");
        debug("Case 5: 1.3");
          state = 6;
          saveToEEP(String(" "), 1);
          debug("Case 5: 2");
      break;
    case 6: {
        refreshStrip();
      break;
  if(millis() - statePrintDelay > 2000){
    debug(state);
    debug("eeprom:");
    debug(arguments);
  refreshStrip();
void saveToEEP(String str,int length){
    for (int i = 0; i<100; i++){
        if(i<length){
            EEPROM.write(i,str[i]);
        }else{
            EEPROM.write(i,' ');
String readFromEEP(){
    char letter;
    //just 35 first letters we don't require more at the moment
    char charArray[35];
    for(int i = 0;i<35; i++){
        letter = EEPROM.read(i);
        charArray[i] = letter;
    return String(charArray);
  String result = "";
    debug("connected");
    client.print(url);
      client.print(args);
    // client.println("Connection: close");
    client.println();
  }  else
    result = "failed";
  return result;
    //Get the duration
    //Get the taskid
    debug(taskId);
    charArray[j] = *"";
      return true;
    } else
      return false;
  } else
    return false;
  String result = "";
    result += " ";
    client.flush();
    client.stop();
  return result;
      return true;
  return false;
      return true;
  else return false;
  //Fill with green
    else {
      leds[i] = color;
  strip.show();
      colorFadeLevel++;
    else {
      colorFadeLevel--;
    ledNumber = 24;
    ledNumber = 0;
  if (!taskStarted) {
    taskStarted = true;
  if (calc > 1) {
    calc = 1;
  numberOfLedsOn --;
    numberOfLedsOn = 0;
    isRed = false;
  else {
    isRed = true;
  if (!isRed) {
  else {
    numberOfLedsOn++;
    else {
      return true;
  return false;
  if (DEBUG) {
  if (DEBUG) {
  if (DEBUG) {
