Having troubles syncing when TCP server or client is running?
I’m not sure if it’s a defect in my Spark Core board or in the software itself, but lately I’ve been having some serious issues flashing some new firmware onto my core when running a TCP client or server. I’m not sure if it’s new news or not, but I think I may have found a workaround for anyone else having this issue. The most important part is displaying the D7 LED at the end. When this turns blue, flash your Spark Core and the success rate is much higher than when you can’t see the status.
TCPClient client;
byte server[] = { 10,0,0,5 }; // Rpi server
int port = 17060;
    pinMode(D7, OUTPUT);
    connect_and_send();
    delay(2000);
void connect_and_send()
    for(int i = 0; i < 2; i++)
        if(client.connect(server,port))
            client.println("GET /search?q=unicorn HTTP/1.0");
            client.println("Host: www.google.com");
            client.println("Content-Length: 0");
            client.println();
            break;
    client.stop();
    digitalWrite(D7, HIGH);
    delay(5000);
    digitalWrite(D7, LOW);
The reason is because that longer delay of 5 seconds is also secretly processing the background tasks which is looking for the incoming re-flashing command.
Your client code is also blocking the user loop() from ending for a while, and the Spark Core won’t be able to see the reprogramming command until that happens… or if you add some delay()'s like you figured out.
Another way to do this if you don’t want to have that long delay in your application code… just look for an input to be shorted to ground in setup(), and if it is… loop forever processing the background tasks. Then re-flash your part… when you see it flashing magenta, remove the short so that when it resets it will power up and run. If you forget to remove the short, it will run as soon as you do.
  // if D2 input is LOW, loop here forever processing the B/G tasks
  pinMode(D2, INPUT_PULLUP);
  while( !digitalRead(D2) ) SPARK_WLAN_Loop();
  // Blink slow (this is our fake application)
  delay(1000);
  delay(1000);
You could also put this in your loop() so that you don’t have to reset you Core. I’ve also made the D7 LED turn on solid to let us know when our loop() hooks into this special reprogramming loop. Don’t add any other code here or that will actually delay your reflashing process. It’s complicated a bit, but because we are forcing the background tasks to run, it can’t lock out the user code from running like it normally does when our code runs to the end of the user loop() and returns control to the spark core’s main() loop. So if we made the led blink fast in our little while() loop, you’d see the magenta flashing rate match the led flashing rate, because it’s allowing one chunk of data to be received each time SPARK_WLAN_Loop() is called. So if we don’t do much, and call it a lot, it will get done much faster.
  while( !digitalRead(D2) ) {
    SPARK_WLAN_Loop();
    // Turn on D7 led solid so we know it's time to re-flash!
  delay(1000);
  delay(1000);
