Mod edit (@harrisonhjones): Solution: Use System.reset()
to issue a reset with code
Hello and Happy New Year to all
I would like to ground the reset pin with a NPN transistor.
I need to reset the photon via Blynk app and dont have much room in my project for a relay. I though of using a transistor. Receive a HIGH from a digital pin to ground the reset pin.
Could someone tell me if a BC337 would do the job and if so, what resistor values to use.
Thanks in advance!
Do you actually need to do that via hardware or would calling System.reset()
via a virtual pin suffice?
The problem with your approach will be that you’d need extra hardware to keep the transistor switched long enough for a proper reset, since your digital pin will fail to hold the required signal almost instantly.
That will suffice. Thank you. Give it a try soon.
I have accomplished it with a relay and works every time. Just wanted to save room.
So is that all is needed?
System.reset();
The switching speed of a transistor is magnitudes higher than that of a relay.
BLYNK_WRITE(10)
if (param.asInt()) {
System.reset();
else
This didn’t work. I don’t think I’m writing the code correctly.
You want to use a virtual pin and try it without condition first
BLYNK_WRITE(V1)
System.reset();
2 posts were split to a new topic: Using transistor instead of a relay
