Hello guys,
I am using for a project your example sketch for temperature sensor (tmp35).
The problem is that i am getting whole time wrong values.
I tried different temperature sensors and two different spark cores
The problem is the same.
Here are the values I received.
Yes I just copy and pasted the code from the docs page und the input was the right one.
I solved this problem:
after I reconnected, factory reseted and uploaded the sketch several times it works
I guess it was magic but thx for your help anyway
