Excessively high reading from TMP36
I was tinkering around with the core and playing with some of the examples and the one with the TMP36 sensor is giving me some odd return values.
I’ve got 3 of the sensors (all giving a reading within 1 degree of each other) but with a plain vanilla setup as in your demo I’m getting a mv reading of ~ 1291 which is 55 degrees celcius? I’ve tried a couple of the other analog pins but not joy - any thoughts/pointers?
Chris
Already solved here: https://community.spark.io/t/odd-analog-readings
Put the 0.1uF cap from analog pin to gnd, as close as possible to the TMP36,
and everything will be fine.
Thanks very much for that - very informative and helpful
You’ll want to keep the capacitance limited to 0.01uF max, due to some restrictions listed in the TMP36’s datasheet. Some have tried the 0.1uF without problems, but if you can find a “103” 0.01uF, it would be good to.
All looking good now - again. Appreciate the help.
