[SOLVED]Particle flash error "Error writing firmware...no known App found."
I’m trying to flash photon from command line with command particle flash --usb photon test.bin
It gives me the error:
Found DFU device 2b04:d006
I’m always programming like that. What changed and I see that error suddenly?
Try leaving out the ‘photon’.
Thanks solved my problem.
No problem. For future reference: https://docs.particle.io/reference/cli/#compiling-remotely-and-flashing-locally
