On Windows 10, with latest Particle Dev and my shiny new Electron! I get this error (at the bottom of post) when I try to open up the serial monitor inside Particle Dev. I followed the [Particle Official] Windows Guide which I thought I aced, but can't seem to flash it locally or see what's going on via the serial monitor in Particle Dev or trying to flash it via the CLI.
How do I figure out where the monkey wrench is?
Thank you!
Jose
In Listening Mode (blue blinky)
In CMD, If I type dfu-util -l I get:
dfu-util 0.8
If I put the Electron in DFU mode (yellow blinky)
it'll add the following lines.
Found DFU: [2b04:d00a] ver=0200, devnum=2, cfg=1, intf=0, alt=1, name="@DCT Flash /0x00000000/01016Kg", serial="00000000010C"
Found DFU: [2b04:d00a] ver=0200, devnum=2, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03016Ka,01016Kg,01064Kg,07*128Kg", serial="00000000010C"
If I try particle flash --serial firmware.bin
I get:
C:\Users\joe\Downloads>particle flash --serial firmware.bin
! PROTIP: Hold the SETUP button on your device until it blinks blue!
? Press ENTER when your device is blinking BLUE
! serial: No devices available via serial
Error in Particle Dev:
Error: Invalid port specified: undefined at new SerialPort (C:\Users\joe\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\node_modules\serialport\serialport.js:134:13) at SerialMonitorView.module.exports.SerialMonitorView.connect (C:\Users\joe\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\views\serial-monitor-view.js:224:19) at SerialMonitorView.module.exports.SerialMonitorView.toggleConnect (C:\Users\joe\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\views\serial-monitor-view.js:208:21) at HTMLButtonElement.<anonymous> (C:\Users\joe\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\atom-space-pen-views\node_modules\space-pen\lib\space-pen.js:220:36) at HTMLButtonElement.jQuery.event.dispatch (C:\Users\joe\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\jquery\dist\jquery.js:4435:9) at HTMLButtonElement.elemData.handle (C:\Users\joe\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\jquery\dist\jquery.js:4121:28)
