[Particle Official] Windows 10 Full CLI and DFU Setup
I’m adding this here in case I forget how I fixed it and hopefully for others in the future:
The guide above talks about using Zadgig for the DFU mode, but it’s easy to mess up and set the driver for your standard Electron, which will break the particle serial identify command.
TO FIX IT:
Your electron setup from Zadig should look like this:
Your DFU setup should be as the guide describes.
