[SOLVED] Core in DFU mode fails to enumerate
I have a core, that when plugged in through USB, OS X “fails to enumerate” the USB device…
I can put the core into DFU mode and dfu-util does not find it…
This is the output I see when I plug in the device, before I set the device into DFU mode… Once I put the device into DFU mode, I don’t see any more output in Console and dfu fails to list the device.
3 other devices work fine. Tried swapping out USB cables, did not work…
Thoughts? The core flashes fine OTA and interacts with tinker…
7/21/14 9:59:04.000 AM kernel[0]: USBF:    88000.591    The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 2 of Hub at 0x1a100000)
7/21/14 9:59:04.000 AM kernel[0]: USBF:    88001. 45    The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x14000000)
7/21/14 9:59:07.000 AM kernel[0]: USBF:    88003.590    The IOUSBFamily was not able to enumerate a device.
7/21/14 9:59:08.000 AM kernel[0]: USBF:    88004.431    The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 2 of Hub at 0x1a100000)
7/21/14 9:59:09.000 AM kernel[0]: USBF:    88005.512    The IOUSBFamily was not able to enumerate a device.
7/21/14 9:59:10.000 AM kernel[0]: USBF:    88006.825    The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x14000000)
7/21/14 9:59:11.000 AM kernel[0]: USBF:    88007.828    The IOUSBFamily was not able to enumerate a device.
7/21/14 9:59:12.000 AM kernel[0]: USBF:    88008.657    The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 2 of Hub at 0x1a100000)
7/21/14 9:59:13.000 AM kernel[0]: USBF:    88009.487    The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 2 of Hub at 0x1a100000)
7/21/14 9:59:13.000 AM kernel[0]: USBF:    88009.487    The IOUSBFamily was not able to enumerate a device.
7/21/14 9:59:15.000 AM kernel[0]: USBF:    88011.689    The IOUSBFamily was not able to enumerate a device.
7/21/14 9:59:16.000 AM kernel[0]: USBF:    88013.  3    The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 3 of Hub at 0x14000000)
7/21/14 9:59:18.000 AM kernel[0]: USBF:    88014.318    The IOUSBFamily gave up enumerating a USB device after 10 retries.  (Port 3 of Hub at 0x14000000)
7/21/14 9:59:18.000 AM kernel[0]: USBF:    88014.318    The IOUSBFamily was not able to enumerate a device.
Doh… Turns out that 2 usb cables were failing… oye… worked with a 3rd cable…
