My OS is ubuntu 13.10. I have build .bin file and put the core into DFU mode.
I use dfu-util can’t list address…
Here is my system message
[2945790.480093] usb 3-1: new full-speed USB device number 4 using uhci_hcd
[2945790.647113] usb 3-1: New USB device found, idVendor=1d50, idProduct=607f
[2945790.647123] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[2945790.647127] usb 3-1: Product: CORE DFU
[2945790.647131] usb 3-1: Manufacturer: Spark Devices
Here is dfu-util -l
Found Runtime: [0b05:1712] devnum=0, cfg=1, intf=2, alt=0, name="UNDEFINED"
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=0, name="UNDEFINED"
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=1, name=“UNDEFINED”
I can’t get the address likes “0x08005000” on github document.
Hmm, maybe try updating dfu-util? It looks like you’re running 0.5, and the latest is 0.7.
It also looks like your core either isn’t connected to your computer, or it isn’t in DFU mode. Make sure your core is blinking yellow by putting it into dfu mode (hold down both buttons, let go of “reset”, and then keep holding mode until it blinks yellow.) If it was in DFU mode, maybe try a different usb cable?
@Dave…Thanks for that. I changed my cable and updated to 0.7…and I think it was able to find the Spark Core. I got some additional lines of output on dfu-util -l. But now when I try to flash the frimware it says it cannot open the device.
Here is the exact output: ~/Desktop/Spark/core-firmware/build$ dfu-util -l
dfu-util 0.7
Copyright 2005-2008 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2012 Tormod Volden and Stefan Schmidt
Found Runtime: [13d3:3315] devnum=0, cfg=1, intf=3, alt=0, name="UNDEFINED"
:~/Desktop/Spark/core-firmware/build$ dfu-util -d 1d50:607f -a 0 -s 0x08005000:leave -D core-firmware.bin
dfu-util 0.7
Filter on vendor = 0x1d50 product = 0x607f
Cannot open device
Hi @Dave and @gtg662w. Just for the record, I was having the same problem with the ‘dfu-util’ commands and was getting the ‘Cannot open device’ output, but once I started using ‘sudo’ everything went well. I’m having the white LED problem this thread is talking about: , and I think I haven’t been able to reflash the firmware, but that I will talk about in the other post (in case you do now what problem I’m having, in which case I’m all ears… Eyes, whatever). Will ask there as soon as I upgrade the ‘dfu-util’ to version 0.7.
My first output:
Command: sudo dfu-util -l
dfu-util 0.5
(C) 2005-2008 by Weston Schmidt, Harald Welte and OpenMoko Inc.
(C) 2010-2011 Tormod Volden (DfuSe support)
dfu-util does currently only support DFU version 1.0
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/20*001Ka,108*001Kg"
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=1, name="@SPI Flash : SST25x/0x00000000/512*04Kg"
Second output:
Command: ~/SparkCore/core-firmware/build$ sudo dfu-util -d 1d50:607f -a 0 -s 0x08005000 -D core-firmware.bin
dfu-util 0.5
Opening DFU USB device... ID 1d50:607f
Claiming USB DFU Interface...
Determining device status: state = dfuERROR, status = 10
dfuERROR, clearing status
dfuIDLE, continuing
Device returned transfer size 1024
No valid DFU suffix signature
Warning: File has no DFU suffix
@vlvrd@Dave Thanks guys. sudo worked and I now I am able to program locally.
Having some other issues now though. After flashing locally, I am unable to flash over the air using the cloud IDE. Will search the forums for more info.
