Per topic, CLI bombs after acquiring device ID... see blurp below.
P1 was updated and running 0.7.0 firmware.
Photon is running 0.6.3 firmware.
I have detected a Photon connected via USB.
? Would you like to continue with this one? Yes
! The device supports setup via serial.
setting up device XXXXXXXXXXXXXXXXXXX3631
! PROTIP: {} function require(path) {
try {
exports.requireDepth += 1;
return self.require(path);
} finally {
exports.requireDepth -= 1;
} Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cmd\serial.js',
exports: [Function: SerialCommand],
parent:
Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cmd\setup.js',
exports: [Function: SetupCommand],
parent:
Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cli\setup.js',
exports: [Function],
parent: [Object],
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cli\setup.js',
loaded: true,
children: [Object],
paths: [Object] },
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cmd\setup.js',
loaded: true,
children:
[ [Object],
[Object],
[Object],
[Object],
[Object],
[Circular],
[Object] ],
paths:
[ 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cmd\node_modules',
'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\node_modules',
'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\node_modules',
'C:\Users\JAmos\AppData\Roaming\npm\node_modules',
'C:\Users\JAmos\AppData\Roaming\node_modules',
'C:\Users\JAmos\AppData\node_modules',
'C:\Users\JAmos\node_modules',
'C:\Users\node_modules',
'C:\node_modules' ] },
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cmd\serial.js',
loaded: true,
children:
[ Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\node_modules\serialport\lib\index.js',
exports: [Object],
parent: [Circular],
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\node_modules\serialport\lib\index.js',
loaded: true,
children: [Object],
paths: [Object] },
Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\node_modules\node-wifiscanner2\lib\wifiscanner.js',
exports: [Object],
parent: [Circular],
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\node_modules\node-wifiscanner2\lib\wifiscanner.js',
loaded: true,
children: [Object],
paths: [Object] },
Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\lib\deviceSpecs\index.js',
exports: [Object],
parent: [Circular],
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\lib\deviceSpecs\index.js',
loaded: true,
children: [Object],
paths: [Object] },
Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\node_modules\binary-version-reader\main.js',
exports: [Object],
parent: [Circular],
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\node_modules\binary-version-reader\main.js',
loaded: true,
children: [Object],
paths: [Object] },
Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\lib\ymodem.js',
exports: [Function: YModem],
parent: [Circular],
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\lib\ymodem.js',
loaded: true,
children: [Object],
paths: [Object] },
Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\lib\SerialBatchParser.js',
exports: [Function: SerialBatchParser],
parent: [Circular],
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\lib\SerialBatchParser.js',
loaded: true,
children: ,
paths: [Object] },
Module {
id: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\lib\SerialTrigger.js',
exports: [Function: SerialTrigger],
parent: [Circular],
filename: 'C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\lib\SerialTrigger.js',
loaded: true,
children: ,
paths: [Object] } ],
paths:
'C:\node_modules' ] } C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cmd\serial.js C:\Users\JAmos\AppData\Roaming\npm\node_modules\particle-cli\dist\cmd
