Hey all,
When trying to import vector or deque and without using them I’m getting the following:
In file included from /opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/vector:60:0,
from xmas.cpp:11:
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:56: error: macro "min" passed 3 arguments, but takes just 2
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:56: error: macro "max" passed 3 arguments, but takes just 2
max(const _Tp& __a, const _Tp& __b, _Compare __comp)
In file included from ../inc/application.h:29:0,
from xmas.cpp:8:
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected unqualified-id before 'const'
min(const _Tp& __a, const _Tp& __b)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected ')' before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected initializer before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected unqualified-id before 'const'
max(const _Tp& __a, const _Tp& __b)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected ')' before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected initializer before 'const'
from xmas.cpp:11:
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:5: error: 'std::min' declared as an 'inline' variable
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:5: error: template declaration of 'const _Tp& std::min'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:242:7: error: expected primary-expression before 'if'
if (__comp(__b, __a))
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:242:7: error: expected '}' before 'if'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:244:7: error: expected unqualified-id before 'return'
return __a;
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:5: error: 'max' declared as an 'inline' variable
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:5: error: template declaration of 'const _Tp& max'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:263:7: error: expected primary-expression before 'if'
if (__comp(__a, __b))
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:263:7: error: expected '}' before 'if'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:265:7: error: expected unqualified-id before 'return'
return __a;
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:266:5: error: expected declaration before '}' token
I checked some previous code that was working and i’m getting the same issue.
Has anyone come across this?
Kieran
