Hey.
I’m trying to create a map like this:
Stomp.h
#include <map>
typedef std::map<String, String> HeaderMap;
Stomp.cpp
#include <Stomp.h>
HeaderMap map;
But as soon as I include my header file I get a bunch of compiler errors. Can anyone help a Noobie out?
The errors I get are:
In file included from /opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_tree.h:61:0,
from /opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/map:60,
from Stomp.h:34,
from dizplay.cpp:2:
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:56: error: macro "min" passed 3 arguments, but takes just 2
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:56: error: macro "max" passed 3 arguments, but takes just 2
max(const _Tp& __a, const _Tp& __b, _Compare __comp)
In file included from ../inc/application.h:29:0,
from dizplay.cpp:2:
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected unqualified-id before 'const'
min(const _Tp& __a, const _Tp& __b)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected ')' before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected initializer before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected unqualified-id before 'const'
max(const _Tp& __a, const _Tp& __b)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected ')' before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected initializer before 'const'
from Stomp.h:34,
from dizplay.cpp:2:
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:5: error: 'std::min' declared as an 'inline' variable
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:5: error: template declaration of 'const _Tp& std::min'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:242:7: error: expected primary-expression before 'if'
if (__comp(__b, __a))
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:242:7: error: expected '}' before 'if'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:244:7: error: expected unqualified-id before 'return'
return __a;
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:5: error: 'max' declared as an 'inline' variable
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:5: error: template declaration of 'const _Tp& max'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:263:7: error: expected primary-expression before 'if'
if (__comp(__a, __b))
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:263:7: error: expected '}' before 'if'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:265:7: error: expected unqualified-id before 'return'
return __a;
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:266:5: error: expected declaration before '}' token
make: *** [dizplay.o] Error 1
Moors7
November 24, 2014, 6:38pm
3
Is that your complete code, or only part of it? If only partial, would you mind sharing the full code?
Don’t mind at all. Here it is.
Stomp.h
#ifndef STOMPC_H
#define STOMPC_H
#include <map>
#include "spark_wiring_string.h"
class Frame {
String command;
HeaderMap* headers;
String body;
public:
Frame(String command, HeaderMap* headers, String body);
static Frame unmarshallSingle(String data);
static Frame * unmarshall(String data);
String marshall(String command, String body);
String toString();
Stomp.cpp
#include "Stomp.h"
const int STOMP_EOF = 0;
Frame::Frame(String _command, HeaderMap* _headers, String _body) {
command = _command;
headers = _headers;
body = _body;
if (command == NULL) {
//throw std::exception("command must not be null");
//if (headers == NULL) {
//throw std::exception("headers must not be null");
if (body == NULL) {
//throw std::exception("body must not be null");
String Frame::toString() {
String out = String(command + "\n");
out += "\n";
out += body;
return out;
dizplay.ino (with unimportant stuff removed but includes intact)
#include "Stomp.h"
#include "Adafruit_SSD1306/Adafruit_GFX.h"
#include "Adafruit_SSD1306/Adafruit_SSD1306.h"
...... further down in loop
Frame frame(String("command"), String("body"));
String result = frame.toString()
@michaelkrog : take a look at this post: http://community.spark.io/t/solved-cant-use-vector-or-deque/8242/3 The poster has some of the same errors you are getting. I think they might be related. The OP’s solution is a few posts down.
True.
Changing
#include <map>
to
#undef min
#undef max
#include <map>
...sorted it out
Awesome! I’m glad you got it working!
I tried doing this via the Particle CLI today and I had to add
#undef swap
as well. Not sure if something has changed on the backend, but I thought I’d post that up in case it helps someone.
karelv
March 10, 2016, 3:50pm
9
Hello @michaelkrog ,
Did you get your stomp message working?
If so, my I ask you to share your code with me?
Karel.
Just wanted to confirm that I have the same issues with including standard c++ libraries such as map.
In my case:
#include <map>
Resulting error:
/usr/local/gcc-arm-embedded-gcc-arm-none-eabi-4_8-2014q2-20140609-linux-tar-bz2/arm-none-eabi/include/c++/4.8.4/bits/stl_tree.h:735:25: error: macro "swap" requires 2 arguments, but only 1 given
swap(_Rb_tree& __t);
I was able to fix the issue with:
#unset swap
