When I verified the cloud code (which used to work fine) now I got this error:
In file included from ../inc/spark_wiring.h:29:0,
from ../inc/application.h:29,
from furby_chat.cpp:2:
../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
In file included from /opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/char_traits.h:39:0,
from /opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/string:40,
from /opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/stdexcept:39,
from /opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/array:38,
from furby_chat.cpp:3:
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:56: error: macro "min" passed 3 arguments, but takes just 2
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:56: error: macro "max" passed 3 arguments, but takes just 2
max(const _Tp& __a, const _Tp& __b, _Compare __comp)
In file included from ../inc/application.h:29:0,
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected unqualified-id before 'const'
min(const _Tp& __a, const _Tp& __b)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected ')' before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:193:5: error: expected initializer before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected unqualified-id before 'const'
max(const _Tp& __a, const _Tp& __b)
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected ')' before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:216:5: error: expected initializer before 'const'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:5: error: 'std::min' declared as an 'inline' variable
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:239:5: error: template declaration of 'const _Tp& std::min'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:242:7: error: expected primary-expression before 'if'
if (__comp(__b, __a))
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:242:7: error: expected '}' before 'if'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:244:7: error: expected unqualified-id before 'return'
return __a;
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:5: error: 'max' declared as an 'inline' variable
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:260:5: error: template declaration of 'const _Tp& max'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:263:7: error: expected primary-expression before 'if'
if (__comp(__a, __b))
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:263:7: error: expected '}' before 'if'
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:265:7: error: expected unqualified-id before 'return'
return __a;
/opt/gcc_arm/arm-none-eabi/include/c++/4.8.4/bits/stl_algobase.h:266:5: error: expected declaration before '}' token
make: *** [furby_chat.o] Error 1
Which is really hard for me to debug since I was away for some time. All I suspect is there’s some issue with the C++ part.
Here is the code:
#define RANDOM(maxRand) (rand() % maxRand)
#include <array>
// Node server on EC2
TCPClient client;
byte server[] = { 54, 68, 214, 214 };
int port = 8080;
// ISR variables
volatile bool padded = false;
volatile bool poked = false;
volatile bool tilted = false;
volatile bool noisy = false;
// TCPClient buffers
uint8_t giggle[] = {'g', 'i', 'g', 'g', 'l', 'e'};
uint8_t adore[] = {'a', 'd', 'o', 'r', 'a', 'b', 'l', 'e'};
uint8_t whoa[] = {'k', 'n', 'o', 'c', 'k', ' ', 'i', 't', ' ', 'o', 'f', 'f'};
uint8_t loud[] = {'S', 'H', 'O', 'U', 'T'};
// for debounce
long lastPoked = 0;
long lastPadded = 0;
long lastTilted = 0;
long lastNoisy = 0;
long debounceDelay = 10;
long noiseDetectionDelay = 1000;
const int statusPin = D0;
const int pokePin = D1;
const int padPin = D4;
const int tiltPin = D5;
const int noisePin = A1;
const int motorPin = A0;
// the only Spark.function to request
int chat(String word) {
motor();
speak(word);
pinMode(statusPin, OUTPUT);
pinMode(pokePin, INPUT_PULLUP);
pinMode(padPin, INPUT_PULLUP);
pinMode(tiltPin, INPUT_PULLUP);
pinMode(noisePin, INPUT_PULLUP);
pinMode(motorPin, OUTPUT);
Spark.function("chat", chat);
// For debugging
Serial.println("connecting...");
delay(10);
Serial.flush();
// For EMIC2
Serial1.begin(9600);
delay(3000);
Serial1.print('\n');
delay(10);
Serial1.flush();
Serial1.println();
// Set volume (-48 to 18)
Serial1.println("V18");
// Set voice (0 - 8) (Not available via DECTalk)
Serial1.println("N4");
// Set rate (75 - 600)
Serial1.println("W150");
// Set Parser (0 = DECTalk, 1 = Epson)
Serial1.println("P0");
attachInterrupt(pokePin, isPoked, FALLING);
attachInterrupt(padPin, isPadded, FALLING);
attachInterrupt(tiltPin, isTilted, FALLING);
client.connect(server, 8081);
connectStatus();
moveAndTalk();
detectNoise();
void motor() {
analogWrite(motorPin, 255);
delay(1500);
analogWrite(motorPin, 0);
// Deal with the byte array
template<std::size_t N>
void sendServer(const uint8_t (&a)[N]) {
if ( client.connect(server, 8081) ) {
Serial.println("connected, writing to EC2");
client.write(a, N);
delay(500);
Serial.println("stopping client...");
client.flush();
client.stop();
} else Serial.println("not able to connect");
// Trigger movement and sound
void moveAndTalk() {
// if noisy is true
if (noisy) {
// set noisy to the current clock
lastNoisy = millis();
// speak out
speak("What's that noise?");
//sendServer(loud);
noisy = false;
if ((millis() - lastNoisy) > noiseDetectionDelay) {
if (noisy) {
noisy = false;
if (tilted) {
lastTilted = millis();
if ((millis() - lastTilted) > debounceDelay) {
if (digitalRead(tiltPin) == LOW) {
motor();
speak("[:pitch 550] Woh [:pitch 250] Aah!");
sendServer(whoa);
if (tilted) {
tilted = !tilted;
// If variable changed due to noise
if (poked) {
lastPoked = millis(); // reset the clock to track that
// Now whatever that was, it's still here after the debounceDelay
if ((millis() - lastPoked) > debounceDelay) {
// Well, if the pin is still LOW
if (digitalRead(pokePin) == LOW) {
motor();
speak("[:pitch 550] Wha [:pitch 250] Ha ha ha!");
sendServer(giggle);
if (poked) {
poked = !poked;
if (padded) {
lastPadded = millis(); // reset the clock to track that
if ((millis() - lastPadded) > debounceDelay) {
if (digitalRead(padPin) == LOW) {
motor();
speak("[:pitch 550] Love [:pitch 220] yoo.");
sendServer(adore);
if (padded) {
padded = !padded;
int speak(String word) {
Serial.println(word);
Serial1.print("S");
Serial1.print("[:phoneme arpabet speak on]");
Serial1.print("[:dv ap 450]");
Serial1.print(word);
Serial1.println();
return 1;
// LED status
void connectStatus() {
if ( client.connected() ) {
// digitalWrite LED to ORANGE
//digitalWrite(D0, HIGH);
if ( WiFi.ready() ) {
// digitalWrite LED to CYAN
digitalWrite(statusPin, HIGH);
while ( WiFi.connecting() ) {
// digitalWrite LED to GREEN
delay(500);
digitalWrite(statusPin, LOW);
delay(500);
if ( WiFi.listening() ) {
// digitalWrite LED to BLUE
if ( !WiFi.hasCredentials() ) {
WiFi.setCredentials("MyWifi", "MyWifiPassword");
// Interrupt Service Routines
void isPadded() {
padded = !padded;
void isPoked() {
poked = !poked;
void isTilted() {
tilted = !tilted;
void isNoisy() {
noisy = !noisy;
