Cant complie a code but by adding a comment it compiles
Im trying to write a library but coming up to a strange error with the webIDE. its probably something I’m doing wrong but its causing a very strange bug
The code fails with the error below, which i cant work out… there is the normal IPAddress warnings, but the strange ones are the previous declaration of void setup() and void loop().
If i add a comment at the top it goes away… or if i delete the first line (blank line) it goes away. only seems to happen when the include application bit is on line 2 or lower, but if there is a comment in the first line its ok. I’ve tried other apps and they dont have the same thing with what line the include is on.
In file included from ../inc/spark_wiring.h:30:0,
                       from ../inc/application.h:29,
                       from SPI_Motor.h:35,
                       from SPI_Motor.cpp:35:
      ../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
      In file included from ../inc/spark_wiring.h:37:0,
      ../inc/spark_wiring_ipaddress.h: In member function 'IPAddress::operator uint32_t()':
      ../inc/spark_wiring_ipaddress.h:53:52: warning: dereferencing
type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
        operator uint32_t() { return *((uint32_t*)_address); };
      ../inc/spark_wiring_ipaddress.h: In member function 'bool IPAddress::operator==(const IPAddress&)':
      ../inc/spark_wiring_ipaddress.h:54:72: warning: dereferencing
        bool operator==(const IPAddress& addr) { return (*((uint32_t*)_address)) == (*((uint32_t*)addr._address)); };
      ../inc/spark_wiring_ipaddress.h:54:105: warning: dereferencing
                       from dualdcmotor.cpp:2:
      dualdcmotor.cpp:4:6: error: previous declaration of 'void setup()' with 'C++' linkage
       void setup();
      In file included from ../inc/spark_wiring.h:34:0,
      ../inc/spark_utilities.h:141:35: error: conflicts with new declaration with 'C' linkage
       void setup() __attribute__ ((weak));
      dualdcmotor.cpp:5:6: error: previous declaration of 'void loop()' with 'C++' linkage
       void loop();
      ../inc/spark_utilities.h:142:34: error: conflicts with new declaration with 'C' linkage
       void loop() __attribute__ ((weak));
      make: *** [dualdcmotor.o] Error 1
    Error: Could not compile. Please review your code.
Here are the files
dualDCmotor.ino
#include "application.h"
#include "SPI_Motor.h"
SPI_Motor pumpCard(D7, 1, 2);
SPI_Motor stirCard(D7, 2, 2);
    Serial.begin(115200);
    while (!Serial.available()) SPARK_WLAN_Loop();
    if (pumpCard.begin()){
        Serial.println("Pump card Initialised!");
    if (stirCard.begin()){
        Serial.println("Stir card Initialised!");
    pumpCard.resume();
    pumpCard.A(STOP, 0);
    pumpCard.B(STOP, 0);
    stirCard.A(STOP, 0);
    stirCard.B(STOP, 0);
    Serial.println("Starting Motors in 5sec");
    delay(5000);
    Serial.println("Starting Motors now 80% power");
    pumpCard.A(CW,200);
    pumpCard.B(CCW,200);
    stirCard.A(CW,200);
    stirCard.B(CCW,200);
    delay(10000);
    Serial.println("Motor A Brake, Motor B Freewheel");
    pumpCard.A(BRAKE);
    pumpCard.B(STOP);
    stirCard.A(BRAKE,200); //doesn't matter if we send PWM too, makes no difference
    stirCard.B(STOP,200);  //doesn't matter if we send PWM too, makes no difference
    delay(10000);
    Serial.println("Reversing Motor directions now");
    pumpCard.A(CCW,200);
    pumpCard.B(CW,200);
    stirCard.A(CCW,200);
    stirCard.B(CW,200);
    delay(10000);
    Serial.println("Stopping all motors");
    pumpCard.A(STOP, 0); //sets pwm to minimum ready for next operation
    delay(1000);
    Serial.println("Ramping up all motors now");
    pumpCard.A(CW); //setting just the direction, PWM will be same last time it was set
    pumpCard.B(CW);
    stirCard.A(CW);
    stirCard.B(CW);
    int i;
    for(i=0; i<255; i++){
    pumpCard.A(i);
    pumpCard.B(i);
    stirCard.A(i);
    stirCard.B(i);
    delay(115); //ramp from 0 to 255 should take about 30sec (maybe as a guess!!)
    Serial.println("Ramping Down all motors now");
    for(i=255; i>0; i--){
    pumpCard.A(i);
    pumpCard.B(i);
    stirCard.A(i);
    stirCard.B(i);
    Serial.println("Putting both cards to low power mode now");
    pumpCard.standby();
    stirCard.standby();
    Serial.println("Check power consumption now.. quick you have 10seconds!");
    delay(10000);
    Serial.println("Putting both cards to Normal/Run mode now");
    pumpCard.resume();
    stirCard.resume();
SPI_Motor.cpp
  This is a library for Hootie81's Dual DC Motor Shield for Spark Core
 The Dual DC Motor Shield uses a Maxim MAX6966 SPI PWM I/O expander
 to drive a Toshiba TB6612FNG Dual DC motor Driver. The MAX6966 has a SPI
 Interface and allows shields to be stacked in a daisy chain configuration
 minimizing the required I/O. The MAX6966 also has a built in 32kHz PWM
 controller saving the Spark more precious I/O.
 The TB6612FNG is a dual H-Bridge motor controller allowing forward and reverse
 directions and PWM speed control. There is short circuit brake function and
 free wheel functions also. The TB6612FNG will drive 2 DC motors at
 up to 1.2A continuous and 3.2A peak.
 The Card can be configured with solder jumpers, there are 4 options for CS on
 the underside of the card - A0, A1, D0, D1
 on the top side you can choose if the card it the first card and or the last
 card. This sets up the MISO And MOSI lines to pass from card to card.
 For single card choose Y for both First and Last.
 For multiple cards,
    on the bottom most card - choose Y for First, and N for Last
    middle cards will be N for both First and Last
    on the top most card choose N for First and Y for last.
 Card Number will be 1 for the bottom most card, the upper limit it yet to
 be determined, but will probably be limited by RAM on the core or Lag in motor
 control from the need to clock data through multiple cards.
  Written by Chris Huitema. 30/7/14
SPI_Motor::SPI_Motor(uint8_t pinCS) {
    _CS = pinCS;
    _card = 1;
    _total = 1;
SPI_Motor::SPI_Motor(uint8_t pinCS, uint8_t cardNumber, uint8_t cardTotal) {
    _CS = pinCS;
    _card = cardNumber;
    _total = cardTotal;
boolean SPI_Motor::begin(void) {
    pinMode(_CS, OUTPUT);
    digitalWrite(_CS, HIGH);
    SPI.setBitOrder(MSBFIRST);
    SPI.setClockDivider(SPI_CLOCK_DIV4);
    SPI.setDataMode(SPI_MODE1);
    SPI.begin();
    if (checkTotalCards(_total))return true;
    return false;
// remember STOP, CW, CCW, BRAKE are the options for direction_t Type
boolean SPI_Motor::A(direction_t Direction, uint8_t PWM) {
    if (A(Direction) && A(PWM)) return true;
    return false;
boolean SPI_Motor::A(direction_t Direction) { //control option, assumes previous PWM
    uint8_t _AIN1, _AIN2;
    if (Direction == STOP) {
        //set AIN1 low, AIN2
        _AIN1 = 0x00;
        _AIN2 = 0x00;
    } else if (Direction == BRAKE) {
        //set AIN1 High, AIN2
        _AIN1 = 0x01;
        _AIN2 = 0x01;
    } else if (Direction == CW) {
        //set AIN1 High, AIN2 Low
        _AIN1 = 0x01;
        _AIN2 = 0x00;
    } else if (Direction == CCW) {
        //set AIN1 Low, AIN2 High
        _AIN1 = 0x00;
        _AIN2 = 0x01;
    if ((sendToCard(_CMD_AIN1, _AIN1)) && (sendToCard(_CMD_AIN2, _AIN2))) return true;
    return false;
boolean SPI_Motor::A(uint8_t PWM) {
    uint8_t _PWMA = map(PWM, 0, 255, 3, 254); //map it so its actually PWM output (MAX6966 needs 3-254 to output PWM)
    if (sendToCard(_CMD_PWMA, _PWMA)) return true;
    return false;
boolean SPI_Motor::B(direction_t Direction, uint8_t PWM) {
    if (B(Direction) && B(PWM)) return true;
    return false;
boolean SPI_Motor::B(direction_t Direction) { //control option, assumes previous PWM
    uint8_t _BIN1, _BIN2;
        //set BIN1 low, BIN2
        _BIN1 = 0x00;
        _BIN2 = 0x00;
        //set BIN1 High, BIN2
        _BIN1 = 0x01;
        _BIN2 = 0x01;
        //set BIN1 High, BIN2 Low
        _BIN1 = 0x01;
        _BIN2 = 0x00;
        //set BIN1 Low, BIN2 High
        _BIN1 = 0x00;
        _BIN2 = 0x01;
    if ((sendToCard(_CMD_BIN1, _BIN1)) && (sendToCard(_CMD_BIN2, _BIN2))) return true;
    return false;
boolean SPI_Motor::B(uint8_t PWM) {
    uint8_t _PWMB = map(PWM, 0, 255, 3, 254); //map it so its actually PWM output (MAX6966 needs 3-254 to output PWM)
    if (sendToCard(_CMD_PWMB, _PWMB)) return true;
    return false;
boolean SPI_Motor::standby(void) {// puts both back to low power operation.
    uint8_t _STBY = 0x00;
    if ((sendToCard(_CMD_STBY, _STBY)) && (sendToCard(_CMD_CONFIG, _STBY))) return true;
    return false;
boolean SPI_Motor::resume(void) {// puts both back to normal operation.
    uint8_t _STBY = 0x01;
    return false;
boolean SPI_Motor::checkTotalCards(uint8_t total) {
    // If we don't take CS high during this, the data will be pumped all the way back to us and wont effect the motors at all
    int j;
    uint8_t CMD = 0x55; // unique dummy number
    uint8_t DATA = 0xF0; // unique dummy number
    uint8_t _NOOP = 0x00;
    PIN_MAP[_CS].gpio_peripheral->BRR = PIN_MAP[_CS].gpio_pin; //set CS low
    Serial.println("CS set Low");
    SPI.transfer(CMD); //send control byte
    Serial.print(" CMD: ");
    Serial.print(CMD);
    SPI.transfer(DATA); //send data byte
    Serial.print(" DATA: ");
    Serial.print(DATA);
    for (j = 1; j < 10; j++) { //send no-op + blank data to clear data past last card (not required for single card)
        _checkCMD = SPI.transfer(_CMD_NOOP);
        Serial.print(_CMD_NOOP);
        _checkDATA = SPI.transfer(_NOOP);
        Serial.print(_NOOP);
        Serial.print(" CheckCMD: "); //check the return CMD is correct last one should be the CMD sent
        Serial.print(_checkCMD);
        Serial.print(" CheckDATA: "); //check the return Data is correct last one should be the Data sent
        Serial.print(_checkDATA);
        if ((_checkCMD == CMD) && (_checkDATA == DATA)){
            Serial.println(" return match found ");
            PIN_MAP[_CS].gpio_peripheral->BSRR = PIN_MAP[_CS].gpio_pin; //set CS high
            Serial.println("CS set High");
            Serial.print("Expecting: ");
            Serial.print(total);
            Serial.print(" Counted: ");
            Serial.print(j);
            if (total == j) {
                Serial.println("Count matched expected... sweet!!");
                return true;
            else return false;
    Serial.println("Could not calculate total number of cards.. bummer!!");
    return false;
boolean SPI_Motor::sendToCard(uint8_t CMD, uint8_t DATA) {
    int j;
    Serial.print(CMD);
    Serial.print(DATA);
    for (j = 1; j < _card; j++) { //send no-op + blank data to put in correct card (not required for single card)
    PIN_MAP[_CS].gpio_peripheral->BSRR = PIN_MAP[_CS].gpio_pin; //set CS High so the data gets latched in the card
    Serial.println();
    Serial.println("CS set high");
    PIN_MAP[_CS].gpio_peripheral->BRR = PIN_MAP[_CS].gpio_pin; //set CS low, now we clear out the data so it doesn't
    // effect other cards.
    for (j = _card; j < _total; j++) { //send no-op + blank data to clear data past last card (not required for single card)
return true;
SPI_Motor.h
 For multiple cards,
enum direction_t {
}; //these are the control options
class SPI_Motor {
public:
     Constructors:
       Takes CS line for the card
       Sets the card number and total cards if more than one card
       used in daisy-chain mode.
    SPI_Motor(uint8_t); // sets CS and assumes single card
    SPI_Motor(uint8_t, uint8_t, uint8_t); // CS, Card number, total cards
     Begin:
       Sets up the CS Port as output and sets high
       Sets up the SPI
       Checks the total number of cards is correct, returns false if not
    boolean begin(void);
     Motor functions:
        3 different options
            Control word and PWM
            Control word only
            PWM only (faster speed changes as only PWM register changed)
        Control words are:
            STOP    this sets the motor in free wheel mode
            BRAKE   this short circuits the motor pins causing a braking effect
            CW      makes the motor turn in a CW direction
            CCW     makes the motor turn in a CCW direction
       All functions will return true is SPI return data looks correct
    boolean A(direction_t, uint8_t);
    boolean A(direction_t);
    boolean A(uint8_t);
    boolean B(direction_t, uint8_t);
    boolean B(direction_t);
    boolean B(uint8_t);
     Power save options:
       standby() sets the motor controller to low power mode.
       resume()  puts back to normal operation.
    boolean standby(void); // puts the motor controller and IO chip to low power
    boolean resume(void); // puts both back to normal operation.
private:
    enum CMD {
        //These are the control registers for the ports on the Max6966
        _CMD_AIN1 = 0x01, //p1
        _CMD_AIN2 = 0x00, //p0
        _CMD_PWMA = 0x09, //p9
        _CMD_BIN1 = 0x03, //p3
        _CMD_BIN2 = 0x04, //p4
        _CMD_PWMB = 0x05, //p5
        _CMD_STBY = 0x02, //p2 low puts TB6612FNG in Standby
        _CMD_CONFIG = 0x10, // control register for MAX6966 config
        _CMD_NOOP = 0x20 //no-op control register used to pump the Data thru
    // setup variables
    uint8_t _CS; //chip select
    uint8_t _card;  //this instances card number
    uint8_t _total;  //total cards
    uint8_t _checkCMD;  //used for return data checks
    uint8_t _checkDATA;  //used for return data checks
    //function to send the SPI data and check return from card
    boolean sendToCard(uint8_t, uint8_t);
    //function to test how many cards there are.
    boolean checkTotalCards(uint8_t);
This is a known bug. I thought there was another forum thread about it, but I can’t seem to find it now! You’ve obviously found the work-around of having a blank or commented line at the top of your main file.
I reported it, and I think @Dave was the one who told me. It may be related to this announcement made a while back.
Hey hey!
I’ve been improving the build farm code these last few days, so I’ll re-visit this bug. The pre-processor tries to help, but sometimes isn’t super-smart. This usually happens because it noticed that some function declarations are missing, and it picked a bad spot to inject them into the file. Thank you for the test case! I’ll update this thread when this is fixed.
David
Just got bit by this bug. I was about to post a new thread on this then this thread pops up as one of the possible relevant issue (great forum design, btw). I’m making a sous-vide controller, so I add one line of comment on top of the .ino. BAM, compiles.
I think, Spark team really needs to address this issue.
Hi @soemarko,
Sorry about that! We’re working on the build farm during this sprint, I’ll see what’s up. Any chance you have a minimal breaking example? I’ll bake it into a regression test so we can avoid it in the future.
David
It’s in the web IDE, sous-vide.ino, you’re welcome to it, I don’t mind – Arduino based sous vide controller, hardly any secret. I can’t seem to download the source as a zip file (feature request!), it’s late in the AM where I am, I’ll copy and paste each file one by one tomorrow. I think a compiled binary wouldn’t be helpful yeah?
Mean while, here’s the output with comment
Output of arm-none-eabi-size:
text	data	bss	dec	hex
87024	1272	12152	100448	18860
In a nutshell:
Flash used	88296 / 110592	79.8 %
RAM used	13424 / 20480	65.5 %
Without comment:
In file included from ../inc/spark_wiring.h:29:0,
from DS18B20.h:2,
from DS18B20.cpp:1:
from OneWire.cpp:5:
from PID.cpp:1:
from PID_AutoTune_v0.cpp:1:
PID_AutoTune_v0.cpp: In member function 'int PID_ATune::Runtime()':
PID_AutoTune_v0.cpp:49:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if((now-lastTime)<sampleTime) return false;
from sous-vide.cpp:2:
In file included from sous-vide.cpp:2:0:
PID_AutoTune_v0.h:3:0: warning: "LIBRARY_VERSION" redefined [enabled by default]
#define LIBRARY_VERSION 0.0.1
In file included from sous-vide.cpp:1:0:
PID.h:3:0: note: this is the location of the previous definition
#define LIBRARY_VERSION 1.0.0
In file included from sous-vide.cpp:4:0:
OneWire.h:27:0: warning: "FALSE" redefined [enabled by default]
#define FALSE 0
In file included from ../../core-common-lib/CC3000_Host_Driver/cc3000_common.h:38:0,
from ../../core-common-lib/SPARK_Firmware_Driver/inc/hw_config.h:35,
from ../inc/main.h:37,
from ../inc/spark_utilities.h:30,
from ../inc/spark_wiring.h:33,
../../core-common-lib/CC3000_Host_Driver/data_types.h:53:0: note: this is the location of the previous definition
#define FALSE (0)
OneWire.h:28:0: warning: "TRUE" redefined [enabled by default]
#define TRUE 1
../../core-common-lib/CC3000_Host_Driver/data_types.h:57:0: note: this is the location of the previous definition
#define TRUE (!FALSE)
PID.h:12:21: error: expected identifier before numeric constant
#define AUTOMATIC 1
../inc/spark_utilities.h:59:3: note: in expansion of macro 'AUTOMATIC'
AUTOMATIC = 0, SEMI_AUTOMATIC = 1, MANUAL = 2
PID.h:12:21: error: expected '}' before numeric constant
#define AUTOMATIC 1
PID.h:12:21: error: expected unqualified-id before numeric constant
#define AUTOMATIC 1
In file included from ../inc/spark_wiring.h:33:0,
../inc/spark_utilities.h:60:1: error: expected declaration before '}' token
} System_Mode_TypeDef;
make: *** [sous-vide.o] Error 1
Hope this can get you started. Tomorrow, I’ll put everything I have into github or something.
Hi @soemarko,
Can you send me the app id from the url when you have the app open in your browser?
David
This one: 54fdb7fe5fadcf85ae001422 ?
Hi @soemarko,
Awesome, thanks! I reduced that into a 3 file, 15 total line sample build for a regression test.
David
Sweet! I find these sort of “fixes” a bit hinky. Could be a bad port of a library, but I think it’s very important to address this.
Yup! Agreed. :slight_smile:
