I’m not sure if it’s just this code or what, but if I try to use an #include on the first line of the Sparkulator, compilation fails. I’ve included screenshots to illustrate the line number change.
“Bad” code:
Results in:
In file included from ../inc/spark_wiring.h:30:0,
from ../inc/application.h:31,
from wi-3d.cpp:2:
../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
In file included from wi-3d.cpp:1:0:
elapsedMillis.h: In constructor 'elapsedMillis::elapsedMillis()':
elapsedMillis.h:30:36: error: 'millis' was not declared in this scope
elapsedMillis.h: In constructor 'elapsedMillis::elapsedMillis(long unsigned int)':
elapsedMillis.h:31:49: error: 'millis' was not declared in this scope
... ommitted for brevity ...
make: *** [wi-3d.o] Error 1```
Good code:
<img src="/uploads/particle/1332/eae9ce848cc2e8e1.PNG" width="223" height="135">
Results in:
```Code verified! Great work.```
