Need help understanding spark core err messages for compilation
In file included from ../inc/spark_wiring.h:30:0,
                       from ../inc/application.h:29,
                       from DS18B20.h:2,
                       from DS18B20.cpp:1:
      ../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
                       from LiquidCrystal/LiquidCrystal.cpp:1:
                       from OneWire/OneWire.h:8,
                       from OneWire/OneWire.cpp:131:
      In file included from OneWire/OneWire.cpp:131:0:
      OneWire/OneWire.h:31:0: warning: "FALSE" redefined [enabled by default]
       #define FALSE 0
      In file included from ../../core-common-lib/CC3000_Host_Driver/cc3000_common.h:38:0,
                       from ../../core-common-lib/SPARK_Firmware_Driver/inc/hw_config.h:35,
                       from ../inc/main.h:37,
                       from ../inc/spark_utilities.h:30,
                       from ../inc/spark_wiring.h:34,
      ../../core-common-lib/CC3000_Host_Driver/data_types.h:53:0: note: this is the location of the previous definition
       #define FALSE         (0)
      OneWire/OneWire.h:32:0: warning: "TRUE" redefined [enabled by default]
       #define TRUE  1
      ../../core-common-lib/CC3000_Host_Driver/data_types.h:57:0: note: this is the location of the previous definition
       #define TRUE          (!FALSE)
                       from OneWire.cpp:4:
                       from ds18b20_w_lcd.cpp:2:
      In file included from ds18b20_w_lcd.cpp:2:0:
      OneWire.h:20:0: warning: "FALSE" redefined [enabled by default]
       #define FALSE 0
       #define FALSE         (0)
      OneWire.h:21:0: warning: "TRUE" redefined [enabled by default]
       #define TRUE 1
      In file included from ds18b20_w_lcd.cpp:40:0:
      DS18B20.h:4:7: error: redefinition of 'class DS18B20'
       class DS18B20{
      In file included from ds18b20_w_lcd.cpp:5:0:
      DS18B20.h:4:7: error: previous definition of 'class DS18B20'
       class DS18B20{
      ds18b20_w_lcd.cpp:78:1: error: expected declaration before '}' token
      make: *** [ds18b20_w_lcd.o] Error 1
    Error: Could not compile. Please review your code.
These seem to be the only important messages.
Forget about the carrets ^ to start with and look at the given line numbers and the surrounding code lines.
Try to have a look in those two ds18b29 lib files. I'll have a quick glance as well (if you can give me a link to the version you're using)
Can you locate the redefinition of DS18B20? If you get rid of that one, the rest might go with it.
Edit: Just seen you filed another issue
http://community.spark.io/t/include-libraries-duplicates-existing-libraries-deleting-one-deletes-both/6657
this may well be in connection with it
It looks like a duplicate definition from the DS18B20.h header. That can happen when a header file is pulled in more than once. Check that the header has
#pragma once
at the top and this will stop that from happening.
ok - thanks for your help guys.
I’m new to spark and haven’t done that much with arduino, but it seems like there are a lot of things that are not supported on spark that are available on arduino?
I’m trying to figure out the following:
rauduino_port_attempt.cpp:79:92: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
brauduino_port_attempt.cpp:79:92: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
brauduino_port_attempt.cpp:84:3: error: ‘B01000’ was not declared in this scope
unsigned long windowStartTime;
brauduino_port_attempt.cpp:85:3: error: ‘B10100’ was not declared in this scope
unsigned long start;
brauduino_port_attempt.cpp:86:3: error: ‘B01000’ was not declared in this scope
brauduino_port_attempt.cpp:87:3: error: ‘B00011’ was not declared in this scope
double Setpoint, Input, Output,eepromKp, eepromKi, eepromKd;
brauduino_port_attempt.cpp:88:3: error: ‘B00100’ was not declared in this scope
//boolean autoLoop = false;
brauduino_port_attempt.cpp:89:3: error: ‘B00100’ was not declared in this scope
bool manualLoop = false;
brauduino_port_attempt.cpp:90:3: error: ‘B00011’ was not declared in this scope
bool waterAdd = false;
brauduino_port_attempt.cpp:91:3: error: ‘B00000’ was not declared in this scope
bool Conv_start = false;
brauduino_port_attempt.cpp: In function ‘void load_pid_settings()’:
brauduino_port_attempt.cpp:254:47: error: expression list treated as compound expression in functional cast [-fpermissive]
Temp_c = (raw & 0xFFFC) * 0.0625;
Relevant code for above:
char* stgName[] ={
  "MashIn","Stage1","Stage2","Stage3","Stage4","Stage5","Stage6","Stage7","Stage8","Boil  "};
// degree c sybmol
byte degc[8] =
  B01000,
  B10100,
  B01000,
  B00011,
  B00100,
  B00100,
  B00011,
  B00000,
and:
brauduino_port_attempt.cpp:555:65: error: ‘word’ was not declared in this scope
stage_timing(stage);
I noticed that this issue was mentioned here: https://community.spark.io/t/porting-arduinolifx-a-lifx-bulb/6794/10 but I wasn’t clear on how it was resolved?
for lowByte and highByte - I just include:
#define lowByte(w) ((uint8_t)((w) & 0xFF))
#define highByte(w) ((uint8_t)((w) >> 8))
at the top of the sketch?
The sketch I’m attempting to port is here: https://github.com/mathoaus/braumiser-controller/blob/master/brauduino2.ino if you want to see if you get the same messages
@lael, first, you can ignore the warnings. For the Spark, binary values are expressed as 0Bxxxxx so you are missing the leading “zero”. There is a missing definition for “word” which could be:
#define word(h, l)   (uint16_t)((h << 8) + y)
Finally, the error:
brauduino_port_attempt.cpp: In function 'void load_pid_settings()':
I am not sure why this error exists! You are casting “raw” as an unsigned int which is 4 bytes long but then do a bitwise AND with a 16bit value. Then you multiply by a float constant. Try changing the code as follows:
uint16_t raw = word(data[1], data[0]);
Temp_PID = (float)(raw & 0xFFFF) * 0.0625;
Temp_c = (float)(raw & 0xFFFC) * 0.0625;
Let me know if this works. :slight_smile:
Thanks @peekay123 !
How do I know the differences between spark and arduino - other than by learning the hard way and asking the forum? It seems like there are a number of ‘gotchas’?
ok, trying out the solutions you proposed and getting the following errors:
brauduino_port_attempt.cpp:880:38: error: macro "word" requires 2 arguments, but only 1 given
brauduino_port_attempt.cpp:82:92: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
brauduino_port_attempt.cpp: In function 'void Temperature()':
brauduino_port_attempt.cpp:23:44: error: 'y' was not declared in this scope
void stage_timing (int stage);
brauduino_port_attempt.cpp:216:20: note: in expansion of macro 'word'
brauduino_port_attempt.cpp:259:47: error: expression list treated as compound expression in functional cast [-fpermissive]
brauduino_port_attempt.cpp:260:47: error: expression list treated as compound expression in functional cast [-fpermissive]
brauduino_port_attempt.cpp:261:47: error: expression list treated as compound expression in functional cast [-fpermissive]
Conv_start = false;
brauduino_port_attempt.cpp:264:51: error: expression list treated as compound expression in functional cast [-fpermissive]
brauduino_port_attempt.cpp: In function 'void get_stage_settings()':
brauduino_port_attempt.cpp:560:15: note: in expansion of macro 'word'
brauduino_port_attempt.cpp: In function 'int change_set(int&, int, int, int)':
brauduino_port_attempt.cpp:776:1: warning: no return statement in function returning non-void [-Wreturn-type]
brauduino_port_attempt.cpp: In function 'int change_set(byte&, int, int, int)':
brauduino_port_attempt.cpp:795:1: warning: no return statement in function returning non-void [-Wreturn-type]
EEPROM.write(addr,data);
brauduino_port_attempt.cpp: In function 'void unit_set()':
brauduino_port_attempt.cpp:809:93: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
if (set_change > upper_limit)set_change = upper_limit;
brauduino_port_attempt.cpp:815:14: note: in expansion of macro 'word'
display_lcd(0,1," ");
brauduino_port_attempt.cpp:807:7: warning: unused variable 'windowSizeSet' [-Wunused-variable]
brauduino_port_attempt.cpp: In function 'void set_stages()':
brauduino_port_attempt.cpp:866:17: note: in expansion of macro 'word'
display_lcd(0,1,setName[i]);
brauduino_port_attempt.cpp:880:24: error: 'word' was not declared in this scope
make: *** [brauduino_port_attempt.o] Error 1
I removed the warnings
This should probably be
#define word(h, l)   (uint16_t)((h << 8) + l)
This is the reason for
And when using this makro you'd need to supply the high and low byte.
I guess you have only supplied one value, which caused this
But to know this, we'd need to see the code snippet the compiler complains about.
Maybe if you correct these errors, others might disappear too.
Since the error messages are quite clear, I'd feel like asking, have you actually had a look at them?
And some basic cross-checking before copy-pasting code of others, might help too.
@ScruffR, OMG!!! I have to stop parking my brain like that :stuck_out_tongue: You are correct with the syntax. As for the single argument error, I missed a line in the brauduino2.ino code that uses a single argument. To fix this, a single argument #define needs to be added:
#define word(w)   (uint16_t)(w)
That and the previous definition should fix the errors. :smile:
Hi Guys,
Thanks so much for the help. ScuffR - I’m fairly new to Arduino programming and there is a lot I don’t really understand as well as I would like. The code was not written by me, which is partially why I’m having trouble understaning what to do with it to fix it. How does the word() macro actually work?
I’m getting this error now:
brauduino_port_attempt.cpp:23:0: warning: "word" redefined [enabled by default]
brauduino_port_attempt.cpp:22:0: note: this is the location of the previous definition
void start_time (void);
brauduino_port_attempt.cpp:883:39: error: macro "word" requires 2 arguments, but only 1 given
brauduino_port_attempt.cpp:85:92: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
brauduino_port_attempt.cpp:262:47: error: expression list treated as compound expression in functional cast [-fpermissive]
brauduino_port_attempt.cpp:263:47: error: expression list treated as compound expression in functional cast [-fpermissive]
brauduino_port_attempt.cpp:264:47: error: expression list treated as compound expression in functional cast [-fpermissive]
Conv_start = false;
brauduino_port_attempt.cpp:267:51: error: expression list treated as compound expression in functional cast [-fpermissive]
brauduino_port_attempt.cpp: In function 'bool wait_for_confirm(bool&)':
brauduino_port_attempt.cpp:292:1: warning: no return statement in function returning non-void [-Wreturn-type]
{ //time to shift the Relay Window
brauduino_port_attempt.cpp: In function 'float change_temp(float&, int, int)':
brauduino_port_attempt.cpp:322:1: warning: no return statement in function returning non-void [-Wreturn-type]
if (Button_hold_press(Button_heat)){
brauduino_port_attempt.cpp:779:1: warning: no return statement in function returning non-void [-Wreturn-type]
brauduino_port_attempt.cpp:798:1: warning: no return statement in function returning non-void [-Wreturn-type]
brauduino_port_attempt.cpp:812:93: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
brauduino_port_attempt.cpp:810:7: warning: unused variable 'windowSizeSet' [-Wunused-variable]
brauduino_port_attempt.cpp:883:25: error: 'word' was not declared in this scope
@lael, I did not get the double definition error on my test app but I think I know why. I believe it’s time to ditch the macros and go with two functions. Add these at the top of your app, before setup():
uint16_t word(int w) { return (uint16_t)w; }
uint16_t  word(uint8_t  h, uint8_t  l) { return (uint16_t)((h << 8) + l); }
Don’t forget to remove or comment out the “word” macro definition. :slight_smile:
I see - so some rough primers :wink:
So called macros - like the ones above - are "translated" by a preprocessor before the actual compiler is run.
This means, whenever the preproc finds a verb that was defined (e.g. #define word(h, l) (uint16_t)((h << 8) + l)) somewhere before, it replaces this verb with the second part of the definition.
  uint16_t x;
  uint16_t hibyte = 0x12;  // 0b00010010
  uint16_t lobyte = 0x34;  // 0b00110100
  x = word(hibyte, lobyte);
will be changed into
  uint16_t x;
  x = (uint16_t)((hibyte << 8) + lobyte);
That's for the macro-question.
And now what does this do?
(uint16_t) is a so-called type cast, which tells the compiler to treat the value represented by the following part of the expression as an uint16_t.
And this hibyte << 8 is a 'leftshift by 8 bits' operation and causes 0x12 (0b00010010) to be changed into 0x1200 (0b0001001000000000).
And finally add the lobyte ((0x1200) + 0x34) = 0x1234.
But since macros have to be unique and are - at least by default - not distinguished by their parameter list (as C++ functions are) you got the
Which can be worked around via proper functions as @peekay123 has shown above.
One word of caution.
While the macro or function do "produce" word values, you can't use them for e.g. type casting
  x = (word)somevar;  // this will fail!
@ScruffR, NICE explanation!!! :wink:
@ScruffR - thank you! that is very helpful! So essentially, take two 8 bit values and put them together? Another noob question - why is this being done at all within the sketch - nevermind - I’ll take a look this afternoon and see what I can figure out and then ask to check if I understand :slight_smile:
@peekay123
ok, so you’ve created a sketch to check it out right? I’m curious… why would yours give different results to mine? (I’m using the online editor) - if there is something I’m formatting incorrectly etc, please let me know! I did have a question - I haven’t removed the macros, only commented them out - I’m assuming the compiler won’t read them - is that correct? or does it still read some comments?
ok, these are the resulting errors:
brauduino_port_attempt.cpp:220:14: error: conflicting declaration 'uint16_t raw'
brauduino_port_attempt.cpp:217:18: error: 'raw' has a previous declaration as 'unsigned int raw'
return 1;
brauduino_port_attempt.cpp:265:47: error: expression list treated as compound expression in functional cast [-fpermissive]
brauduino_port_attempt.cpp:268:51: error: expression list treated as compound expression in functional cast [-fpermissive]
return;
**and this is the code as altered:**
#include "OneWire.h"
#include "DS18B20.h"
#include "PID.h"
#include "flashee-eeprom/flashee-eeprom.h"
#include "OneWire/OneWire.h"
#include "LiquidCrystal/LiquidCrystal.h"
//function definitions for spark core:
//#define word(w)   (uint16_t)(w)
//#define word(h, l)   (uint16_t)((h << 8) + l)
//#define word(b1,b2)  (uint16_t(uint8_t(b1)<<8|uint8_t(b2)))
//pin mappings - TODO: check re-mapping to Arduino Uno
// sensor and lcd and buttons
OneWire ds(A5);
LiquidCrystal lcd(D2, D0, D3, D1, A7, D4);
// push buttons
const int Button_up    = A4; //pin 12 on uno
const char Button_dn    = A6;
const char Button_heat = A1; //Button_prev in org //3.3v ONLY //brauduino shield passes in 5v and will blow spark core
const char Button_pump = A0; // in org code    //3.3v ONLY //brauduino shield passes in 5v and will blow spark core
// outputs
const byte Pump = D5;
const byte Buzz = A2;
const byte Heat = D6;
// global variables
unsigned int WindowSize;
bool autoLoop = false;
bool mpump = false;
bool mheat = false;
bool wtBtn = false;
bool autoEnter = false;
bool tempReached = false;
bool pumpRest = false;
//bool boilLoop = false;
bool resume = false;
float mset_temp = 35;
float Temp_c, stageTemp,pumptempError,Temp_PID;
int x;
int  stageTime,hopTime;
byte mainMenu = 0;
byte pumpTime;
byte data[2];
byte second;
//byte minute;
//byte i;
byte Busy = 0;
byte nmbrStgs;
byte nmbrHops;
byte tempHAddr;
byte tempLAddr;
byte timeAddr;
byte blhpAddr;
byte hopAdd;
char* stgName[] ={
// degree c sybmol
byte degc[8] =
  0B01000,
  0B10100,
  0B01000,
  0B00011,
  0B00100,
  0B00100,
  0B00011,
  0B00000,
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,100,20,5, DIRECT);
//****** start of the funtions**************
void Buzzer(int number)
  for (int i=0; i < number; i++)
    digitalWrite (Buzz,HIGH);
    delay (500);
    digitalWrite(Buzz,LOW);
    delay(100);
void pause_stage(void){
  boolean stage_pause = false;
  if (Button_1sec_press(Button_heat)){
    Buzzer(1);
    stage_pause = true;
    digitalWrite(Heat,LOW);
    digitalWrite(Pump,LOW);
    display_lcd(0,0,"     Paused    " );
    while (stage_pause)
      if (Button_1sec_press(Button_heat))stage_pause=false;
void display_lcd (int pos , int line ,const char* lable){
  lcd.setCursor(pos,line);
  lcd.print(lable);
// 1 second button press
int Button_1sec_press (int Button_press){
  if (digitalRead(Button_press)==0){
    delay (1000);
      lcd.clear();
      while(digitalRead(Button_press)==0){
      return 1;
  return 0;
// repeat button press
int Button_repeat (int Button_press){
    delay(200);
    return 1;
  return 0;
// holds whilst button pressed
int Button_hold_press (int Button_press){
  if (digitalRead (Button_press)==0){
    delay(50);
    while (digitalRead (Button_press)==0){
    return 1;
  return 0;
// reads the DS18B20 temerature probe
void Temperature(void){
  ds.reset();
  ds.skip();
  // start conversion and return
  if (!(Conv_start)){
    ds.write(0x44,0);
    Conv_start = true;
    return;
  // check for conversion if it isn't complete return if it is then convert to decimal
  if (Conv_start){
    Busy = ds.read_bit();
    if (Busy == 0){
      return;
    ds.reset();
    ds.skip();
    ds.write(0xBE);
    for ( int i = 0; i < 2; i++) {           // we need 2 bytes
      data[i] = ds.read();
    unsigned int raw = (data[1] << 8) + data[0];
    Temp_PID = (raw&0xFFFF)*0.0625;
    Conv_start = false;
    return;
void PID_HEAT (void){
 if(autoEnter){
  Setpoint = stageTemp;
else{
 Setpoint = mset_temp;
 Input = Temp_PID;
  if((Setpoint - Input)>5){
    digitalWrite(Heat,HIGH);
    if ((Setpoint - Input)<6)
      myPID.Compute();
  else{
    myPID.Compute();
    unsigned long now = millis();
    if(now - windowStartTime>WindowSize)
      windowStartTime += WindowSize;
    if((Output*(WindowSize/100)) > now - windowStartTime) digitalWrite(Heat,HIGH);
    else digitalWrite(Heat,LOW);
void load_pid_settings (void)
  eepromKp = int(EEPROM.read(0),EEPROM.read(1));// read the PID settings from the EEPROM
  eepromKi = int(EEPROM.read(2),EEPROM.read(3));
  eepromKd = int(EEPROM.read(4),EEPROM.read(5));
  eepromKi = eepromKi/100;
  myPID.SetTunings(eepromKp,eepromKi,eepromKd); // send the PID settings to the PID
  WindowSize = int(EEPROM.read(33),EEPROM.read(34));
  myPID.SetOutputLimits(0, 100);
  myPID.SetSampleTime(5000);
bool wait_for_confirm (boolean& test)
  wtBtn = true;
  while (wtBtn){               // wait for comfirmation
      test = true;
      wtBtn = false;
      lcd.clear();
    if (Button_hold_press(Button_pump)){
      test = false;
      wtBtn = false;
      lcd.clear();
float change_temp(float& temp_change,int upper_limit,int lower_limit)
  // Increase set temp
  if (Button_repeat(Button_up)){
    if (temp_change>=100){
      temp_change++;
    else{
      temp_change+=0.25;
    if (temp_change > upper_limit)temp_change = upper_limit;
  // decrease temp
  if (Button_repeat(Button_dn))
    if(temp_change>=100){
      temp_change--;
    else{
      temp_change-=0.25;
    if ( temp_change < lower_limit) temp_change = lower_limit;
void quit_mode (boolean& processLoop)
  if ((digitalRead(Button_dn)==0) && (digitalRead(Button_up)==0)){
    processLoop = false;
    lcd.clear();
void heat_control(void)
  //turns heat on or off
    if (mheat==false){
      mheat = true;
      windowStartTime = millis();
    else{
      mheat = false;
void pump_control(void)
  //turns the pump on or off
    if (mpump == false){
      mpump = true;
      digitalWrite(Pump,HIGH);
    else{
      mpump = false;
void prompt_for_water (void){
  display_lcd(0,0,"  Water added?  ");
  Buzzer(3);
  display_lcd(0,1,"       Ok   Quit");
void pump_prime(void)
  lcd.clear();
  lcd.print("  Pump  Prime  ");  // priming the pump
  delay (1000);
  delay(200);
  delay (1000);
  delay(200);
  delay (1000);
  lcd.clear();
void pump_rest (int stage)
  if (stage==9){
    if (Temp_c<94.0) digitalWrite(Pump,HIGH);
    else digitalWrite(Pump,LOW);
    if (Temp_c >= 95)tempReached = true;
  else{
    pumptempError = stageTemp-Temp_c;
    if (pumptempError <= 0)tempReached = true;
    if ((pumpTime < 10)){ // starts pumps and heat
      pumpRest =false;
    if ((pumpTime >= 10)){ // pump rest
      pumpRest = true;
      if(pumpTime>=12 || (pumptempError > 1.0))pumpTime = 0;
void check_for_resume(void){
  if(EEPROM.read(35)){ // read the auto started byte to see if it has been set and if so ask to resume
    display_lcd (0,0," Resume Process?");
    display_lcd (0,1,"        Yes   No");
    wait_for_confirm(resume);
    if(resume==true){
      tempHAddr = (EEPROM.read(36)*3)+6;
      tempLAddr = tempHAddr+1;
      timeAddr = tempHAddr+2;
      x = EEPROM.read(36);
      autoEnter = true;
      lcd.clear();
void load_stage_settings (void){
  tempHAddr = 6; // setup intitial stage addresses
  tempLAddr = 7;
  timeAddr = 8;
  nmbrStgs = EEPROM.read(38);// read the number of steps
  nmbrHops = EEPROM.read(39);//read the number of hop additions
  start = millis();
  // windowStartTime = millis();
  second = 0;
  // minute = 0;
  if ((millis()-start)>1000){  // timing routine
    start = millis();
    second++;
    if(!(tempReached))second=0;// starts counting down when temp reached
    if (second>59){
      display_lcd(10,0,"      ");
      second = 0;
      pumpTime++;
      if(stage == 0)pumpTime = 0;
      stageTime--;
      EEPROM.write(37,lowByte(stageTime));// saves stage time incase of interuption
void hop_add (void)
  if(hopAdd <= nmbrHops){
    if (stageTime == hopTime){
      Buzzer(3);
      lcd.clear();
      lcd.print("    Add  Hops");
      delay(2000);
      Buzzer(3);
      hopAdd++;
      EEPROM.write(49,hopAdd);
      blhpAddr++;
      hopTime = EEPROM.read(blhpAddr);
      lcd.clear();
void stage_loop (int stage, float H_temp=80, float L_temp=30){
  int lastminute;
  while ((stageTime>0)&&(autoEnter)){
    lastminute=stageTime;
    Temperature();// get temp
    pause_stage();
    if (pumpRest){
      display_lcd(0,0,"   Pump  Rest   ");
    else{
      display_lcd(0,0,stgName[stage]);
      display_lcd(6,0,"     ");
      display_lcd(11,0,"T=");
      lcd.print(stageTime);
      display_lcd(0,1,"S/A=");
      lcd.print(stageTemp);
      display_lcd(9,1,"/");
      lcd.print(Temp_c);
      lcd.write((uint8_t)0);
    change_temp(stageTemp,H_temp,L_temp);
    pump_rest(stage);
    if (pumpRest==false)PID_HEAT();
    if (stage==9){
      if(stageTime<lastminute){
        hop_add();
    quit_mode (autoEnter);
void get_stage_settings (void)
  stageTemp = word(EEPROM.read(tempHAddr),EEPROM.read(tempLAddr));
  stageTemp = stageTemp/16.0;
  if (resume){                 // on the start of resume gets saved time
    stageTime=EEPROM.read(37);
    resume = false;            // clears resume for next loop
  else{
    stageTime = EEPROM.read(timeAddr); // gets stage time
    EEPROM.write(37,lowByte(stageTime));// saves the intial stage time
void add_malt (void)
  boolean malt;
  lcd.clear();
  display_lcd(0,0,"    Add Malt    ");
  Buzzer(3);
  wait_for_confirm(malt);
  if (malt==false){
    lcd.clear();
    delay(50);
    mainMenu=0;
    autoEnter = false;
void remove_malt (void)
  boolean malt;
  lcd.clear();
  x = 9;               // used add to stage count on the final stage for the resume
  EEPROM.write(36,lowByte(x)); // stores the stage number for the resume
  display_lcd(0,0,"  Remove  Malt  ");
  Buzzer(3);
  if (malt==false){
    stageTime = EEPROM.read(40);
    lcd.clear();
    delay(50);
    mainMenu=0;
    autoEnter = false;
void get_boil_settings (void)
  if (resume){
    if(x!=9){
    else{
      stageTime= EEPROM.read(37);
  else{
  hopAdd = EEPROM.read(49);
  blhpAddr = hopAdd+41;
  lcd.clear();
void manual_mode (void)
  load_pid_settings();
  prompt_for_water();
  wait_for_confirm(manualLoop);
  while (manualLoop){            // manual loop
    Temperature();
    display_lcd(0,0,"  Manual Mode   ");
    lcd.print(mset_temp);
    lcd.print(Temp_c);
    change_temp(mset_temp,120,20);
    quit_mode(manualLoop);
    heat_control();
    pump_control();
    if (mheat){
      PID_HEAT();
void auto_mode (void)
  load_stage_settings();
  check_for_resume();
  if(!(resume)){  // if starting a new process prompt for water
    prompt_for_water();
    wait_for_confirm(autoEnter);
    if(!(autoEnter))return;
    pump_prime();
    x = 0;
  if (autoEnter){     // mash steps
    EEPROM.write(35,1);// auto mode started
    for (int i = x;i < nmbrStgs;i++){
      x++;                         // used to count the stages for the resume
      get_stage_settings();
      start_time();
      stage_loop(i);
      if (!(autoEnter)) break;
      if( i==0 && autoEnter){    // at the end of the mashIn step pauses to add grain
        add_malt();
        if (!(autoEnter))break;
      if(i==(nmbrStgs-1)&& autoEnter){   // at the end of the last step pauses to remove the malt pipe before the boil
        remove_malt();
      Buzzer(1);
      tempHAddr +=3; // increase stage addresses
      tempLAddr +=3;
      timeAddr +=3;
      lcd.clear();
  // start of the boil
  if(autoEnter){
    start_time();
    stageTemp= 98.0; // set the intital boil temp to 98 deg c
    get_boil_settings();
    stage_loop(9,120,94);
    if(autoEnter){    // finishes the brewing process
      display_lcd(0,0,"    Brewing     ");
      display_lcd(0,1,"   Finished     ");
      Buzzer(3);
      delay(2000);
      EEPROM.write(35,0); // sets auto start byte to 0 for resume
      EEPROM.write(49,0); // sets hop count to 0
      mainMenu=0;
      autoEnter =false;
      resume =false;
void save_settings (int addr,int data)
  EEPROM.write(addr,highByte(data));
  EEPROM.write((addr+1),lowByte(data));
void save_settings (int addr,byte data){
int change_set(int& set_change,int upper_limit,int lower_limit,int step_size)
    set_change+=step_size;
  // decrease temp
    set_change-=step_size;
  if ( set_change < lower_limit) set_change = lower_limit;
int change_set(byte& set_change,int upper_limit,int lower_limit,int step_size)
  // decrease temp
void unit_set (void)
  int param[] ={
    100,-100,1,100,-100,1,100,-100,1,5000,500,500,9,1,1,8,0,1                  };
  int a = 0;
  boolean pidLoop = false;
  int pidSet,setaddr;
  int windowSizeSet;
  char* setName[] ={
    "Kp = ","Ki = ","Kd = ","Windowsize= ","Num of Stages=","Num of Hops="                  };
  setaddr = 0;
  for(int i=0;i<6;i++){
    if((i>=0) && (i<=3)){
      if (i==3) setaddr = 33;
      pidSet=word(EEPROM.read(setaddr),EEPROM.read((setaddr+1)));
    if (i==4)setaddr = 38;
    if((i>=4) && (i<6)){
      pidSet= EEPROM.read(setaddr);
    pidLoop= true;
    while (pidLoop){
      lcd.print(pidSet);
      change_set(pidSet,param[a],param[a+1],param[a+2]);
      quit_mode(pidLoop);
      if (!(pidLoop))i=6;
      if(Button_hold_press(Button_pump)){
        if (i >= 4){
          save_settings(setaddr,lowByte(pidSet));
          pidLoop = false;
        else{
          save_settings(setaddr,pidSet);
          pidLoop = false;
    if (i>=4){
      setaddr+=1;
    else{
      setaddr+=2;
    a+=3;
void set_stages (void)
  boolean autotempLoop = false;
  boolean autotimeLoop = false;
  tempHAddr = 6;
  tempLAddr = 7;
  timeAddr = 8;
  float stgtmpSet;
  int stgtmpSetword;
  int stgtimSet;
  for (int i=0; i<nmbrStgs;i++){ // loops for the number of stages
    stgtmpSet = word(EEPROM.read(tempHAddr),EEPROM.read(tempLAddr));
    stgtmpSet = stgtmpSet/16.0;
    autotempLoop = true;
    while (autotempLoop){  // loops for temp adjust
      display_lcd(0,1,stgName[i]);
      lcd.print("Temp=");
      lcd.print(stgtmpSet);
      quit_mode(autotempLoop);
      if (autotempLoop == false){
        return;
      change_temp(stgtmpSet,85,20);
        stgtmpSet = stgtmpSet*16;
        stgtmpSetword = word(stgtmpSet); //**error here word requires two par?
        save_settings(tempHAddr,stgtmpSetword);
    autotimeLoop = true;
    stgtimSet = EEPROM.read(timeAddr);
    while (autotimeLoop){ // loops to adjust time setting
      lcd.print(" time=");
      lcd.print(stgtimSet);
      quit_mode(autotimeLoop);
      if (autotimeLoop == false){
        return;
      change_set(stgtimSet,120,0,1);
        save_settings(timeAddr,lowByte(stgtimSet));
    tempHAddr+= 3;
    tempLAddr+= 3;
    timeAddr+= 3;
void set_hops (void)
  boolean hopLoop = false;
  blhpAddr = 40;
  byte hopSet;
  nmbrHops+=1;
  for(int i =0;i<nmbrHops;i++){
    hopLoop = true;
    hopSet = EEPROM.read(blhpAddr);
    while (hopLoop){
      if (i==0){
        display_lcd(0,1,"Boil time = ");
        lcd.print(int (hopSet));
      else{
        display_lcd(0,1,"Hop ");
        lcd.print(i);
        lcd.print(" time = ");
        lcd.print(int(hopSet));
      quit_mode(hopLoop);
      if( hopLoop == false){
        return;
      change_set(hopSet,180,0,1);
        save_settings(blhpAddr,hopSet);
        lcd.setCursor(0,1);
        lcd.print("                ");
        hopLoop = false;
    blhpAddr+= 1;
void auto_set(void)
  set_stages();
  set_hops();
void setup_mode (void)
  byte setupMenu = 0;
  boolean setupLoop = true;
  while (setupLoop){
    switch (setupMenu){ // to select between PID and Auto menu
      case(0):
      display_lcd(0,0,"Unit Parameters ");
      quit_mode(setupLoop);
      if (Button_hold_press(Button_up))setupMenu = 1;
      if (Button_hold_press(Button_pump))unit_set();
      break;
      case(1):
      display_lcd(0,0," Auto Parameters");
      if (Button_hold_press(Button_dn))setupMenu = 0;
      if (Button_hold_press(Button_pump))auto_set();
      break;
  // Start up the library
  lcd.begin(20,4);
  pinMode (Button_up,INPUT);
  pinMode (Button_dn,INPUT);
  pinMode (Button_heat,INPUT);
  pinMode (Button_pump,INPUT);
  pinMode (Heat,OUTPUT);
  pinMode (Pump,OUTPUT);
  pinMode (Buzz,OUTPUT);
  //tell the PID to range between 0 and the full window size
  myPID.SetMode(AUTOMATIC);
  // write custom symbol to LCD
  lcd.createChar(0,degc);
  switch(mainMenu){
    case (1):
    delay (1000);
    lcd.clear();
    manual_mode();
    mainMenu = 0;
    break;
    case (2):
    display_lcd(0,0,"   Auto Mode    ");
    delay (1000);
    lcd.clear();
    auto_mode();
    mainMenu = 0;
    break;
    case (3):
    display_lcd(0,0,"   Setup Mode   ");
    delay (1000);
    lcd.clear();
    setup_mode();
    mainMenu = 0;
    break;
  default:
    Temperature();
    display_lcd(0,0," The Brauduino  ");
    display_lcd(0,1,"  Temp=");
    lcd.print(Temp_c);
    if (Button_1sec_press(Button_dn))mainMenu = 1;
    if (Button_1sec_press(Button_heat))mainMenu = 2;
    if (Button_1sec_press(Button_pump))mainMenu = 3;
    break;
I would recommend posting this in Gist an share the link.
it’s too much code and make it hard to navigate this thread. :slight_smile:
Git? Do you know of a good IDE for windows for it?
I meant Gist.
See http://gist.github.com :wink:
like this?:
Sorry, to be so blunt, but even if you're new to C/C++, Arduino and Spark Core, as said above please read the error messages and look at your own code.
You have a pretty clear error message here
and then you have this code with code lines 217 and 220 and they do actually line up with the gist you posted
    unsigned int raw = (data[1] << 8) + data[0];  // line 217 is the previous declaration of raw
    uint16_t raw = word(data[1], data[0]);  // and here in line 220 you re-declare the SAME variable as different type
Change this into
    uint16_t raw = (data[1] << 8) + data[0];  // is the same as unsigned int on 8/16 bit processors
    Temp_PID = (raw & 0xFFFF) * 0.0625;
    /* Why do you do exactly the same thing twice, anyway????
    raw = word(data[1], data[0]);  // don't re-declare but only use the already declared variable
This would have been easy to find out.
The other errors
for lines 263, 264, 265 and 268 are quite clear as well, when you look at these lines
  eepromKp = int(EEPROM.read(0),EEPROM.read(1)); // 263
  eepromKi = int(EEPROM.read(2),EEPROM.read(3)); // 264
  eepromKd = int(EEPROM.read(4),EEPROM.read(5)); // 265
  WindowSize = int(EEPROM.read(33),EEPROM.read(34)); // 268
int is not a macro or a function as you might assume after using word this way.
That was why I stated "A word of caution", above. A type is not a macro/function and vice versa.
But you could use the word macro/function there to do what you intended.
