I have applied the fixes and workarounds explained on this post: BLE_GROUP: can’t make it work on DeviceOS 3.1
I have now noticed that as soon as the group->scan() is executed (or maybe when the devices connect, I am not sure), both the peripheral and the central devices go blinking green and never reconnect to WiFi.
If I turn off one of them, the WiFi connection for the one that remains on is solid and stable.
But as soon as I power back on the other device (be it the central or the peripheral) the device that was breathing cyan, and happily connected to the Internet, it does the following:
- its LED goes white of a short period of time
- it starts blinking green
After this, the device that I just powered on keeps on blinking green. In fact, both keep blinking green (forever, perhaps?).
I fear there is a potential issue here in BLE_GROUP, at least in DeviceOs3.1.
Here’s code that reproduces this issue. You can see I commented out few lines to try to pinpoint the issue:
Central code:
#include "BLE_Group.h"
BLE_Group *group;
SYSTEM_THREAD(ENABLED);
SerialLogHandler logHandler(LOG_LEVEL_INFO);
unsigned long scan_time;
void callbackFunc(const char *event, const char *data)
Log.info("Event: %s, Data: %s", event, data);
#if SYSTEM_VERSION == SYSTEM_VERSION_v310
// This is required with 3.1.0 only
BLE.setScanPhy(BlePhy::BLE_PHYS_AUTO);
#endif
group = new BLE_Group_Central(1); // The parameter is the groupID
// group->subscribe("test", callbackFunc);
if (group->devices_connected() < BLE_GROUP_MAX_PERIPHERALS && (millis() - scan_time) > 3000)
Log.info("central is about to scan");
group->scan();
scan_time = millis();
// // group->publish("test-central", "Some data");
Log.info("looping in central");
delay(5000);
Peripheral code:
BLE_Group *group;
#endif
group = new BLE_Group_Peripheral(1); // The parameter is the groupID
// group->publish("test-periph", "Some Data");
Log.info("looping in peripheral");
delay(6000);
Now, I have two questions:
- Did I hit another BLE scan issue like the one mentioned in the previous BLE_GROUP post?
- How do I troubleshoot this?
