[Solved] Assistance with "NeoPixels"
I’m working on a little fading routine to take a segment of a neopixel array and “breathe” it.
It works except the pixel Zero also breathes!!
Perhaps someone out there has seen something like this; I’m beside myself trying to understand how pixel zero is getting lit in this code:
#include "application.h"
#include "neopixel.h"
#define PIXEL_COUNT 150
Adafruit_NeoPixel myPixels = Adafruit_NeoPixel(PIXEL_COUNT, D2, WS2812B);
const uint8_t mySegment[8] = {10,11,12,13,14};
  myPixels.begin();
  myPixels.setBrightness(255);
  myPixels.show();
  breatheUpdate(mySegment, 5, 1, 0);
void breatheUpdate(const uint8_t * segment, const uint32_t increment, const uint8_t step, const uint8_t lowLimit)
  static uint32_t lastTimeChange = 0;
  static uint8_t direction = 1;
  static uint8_t value = lowLimit;
  if(millis() - lastTimeChange > increment)
    value += (direction * step);
    if (value <= lowLimit || value >= 255)
      direction = direction * -1;
    for(uint8_t i = 0; i < sizeof(segment) * 2; i++)
      myPixels.setPixelColor(segment[i], myPixels.Color(value, value, value));
    myPixels.show();
    lastTimeChange += increment;
Anyone familiar with the WS2812B who has seen this?
Does your the rest of your animation work as expected?
I’m not sure if your sizeof(segment) actually does what you expect it to do.
As you’ve declared it const uint8_t* I’d expect sizeof() to report four byte (which is the size of a 32bit pointer) and not the size of the array you have it pointing to.
This is the reason why standard C functions that take a pointer to a buffer usually also require you to pass in the length of the buffer, since a pointer is only that - a 32bit number pointing to something.
You can easily test my theory by writing sizeof(mySegments) instead.
And why are you multiplying by * 2?
Your if might also need some rework, since you might not exactly hit 255 depending on your step and since being uint8_t e.g. 254 + step (step being greater than 1) will wrap round possibly resulting in a value greater than lowLimit to giving you a sudden color jump.
thanks for shaking me loose...
const uint8_t mySegment[] = {117,118,119,120};  //<<<<<<<correct, now
uint32_t arraySize = 0;
  Particle.variable("myArray", &arraySize, INT);
  arraySize = sizeof(mySegment);
  myPixels.begin();
  myPixels.show();
    for(uint8_t i = 0; i < sizeof(segment); i++)
    myPixels.show();
the 'fixed' array length....
I didn't notice my error.
yeah, I just tossed that together to pull out the test... Well noted!
:+1: good that it works now, but I still think it only does by coincidence, since your array has four elements and sizeof(segment) fits in this one and only case.
If your array was one element longer or shorter I would expect that your code breaks again.
Just Serial.println(sizeof(segment)) vs. Serial.println(sizeof(mySegment)) after extending your array a bit.
Yes! Understand.
I’ll post it later (at soccer now). I works properly passing sizeof(myArray) along with the pointer to myArray to the function.
Appreciate the help.
@BulldogLowell how did the final script look like and how to let a complete strip breathe?
so here is my function:
void breatheWeather(const uint8_t * segment, const uint8_t numLeds, const uint32_t increment, const uint8_t step)
  const static uint8_t lowLimit = 50;
    value +=(direction * step);
    value = constrain(value, lowLimit, 255);
      direction *= -1;
    for(uint8_t i = 0; i < numLeds; i++)
      myPixels.setPixelColor(segment[i], myPixels.Color(map(value, 0,255,0,weatherColor.red), map(value, 0,255,0,weatherColor.green), map(value, 0,255,0,weatherColor.blue)));
    myPixels.show();
called like this in my word clock:
switch (weather_State) {
    case (SUNSHINE):
      breatheWeather(sunshine_Weather, sizeof(sunshine_Weather), breatheRate, 1);
      break;
    case (SNOW):
      breatheWeather(snow_Weather, sizeof(snow_Weather), breatheRate, 1);
      break;
    case (PARTLY_CLOUDY):
      breatheWeather(partlyCloudy_Weather, sizeof(partlyCloudy_Weather), breatheRate, 1);
      break;
    case (OVERCAST):
      breatheWeather(overcast_Weather, sizeof(overcast_Weather), breatheRate, 1);
      break;
    case (LIGHTNING):
      breatheWeather(lightning_Weather, sizeof(lightning_Weather), breatheRate, 1);
      break;
    case (RAIN):
      breatheWeather(rain_Weather, sizeof(rain_Weather), breatheRate, 1);
      break;
and the segments of the led strip defined like this:
const uint8_t sunshine_Weather[] = {142,143,144,145,146};
const uint8_t partlyCloudy_Weather[] = {137,138,139,140,141};
const uint8_t overcast_Weather[] = {132,133,134,135,136};
const uint8_t lightning_Weather[] = {127,128,129,130,131};
const uint8_t rain_Weather[] = {122,123,124,125,126};
const uint8_t snow_Weather[] = {117,118,119,120, 121};
non-blocking method to breathe a sub-segment of a NeoPixel ledstrip.
you can just re-factor for your whole strip…
as @ScruffR pointed out, watch the boundaries, This worked for me and I let it be!
Thanks! @BulldogLowell, last question, where do weatherColor.red, green, blue come from and what is it?
so, This is my version of a weather clock… I am defining the color of the illumination of different sub-segments of the LEDs like this:
struct colorObject{
  uint8_t red;
  uint8_t green;
  uint8_t blue;
const colorObject briteWhite = {255,255,255};
const colorObject skyBlue = {50,50,255};
const colorObject allRed = {0,255,0};
const colorObject allBlue = {0,0,255};
const colorObject yellowSun = {255,255,30};
const colorObject greenGrass = {255,0,0};
const colorObject dullGray = {125,125,125};
colorObject timeColor = briteWhite;
colorObject mailColor = briteWhite;
colorObject weatherColor = allBlue;
looks like this video:
I'm still tinkering here but this is the code I am working with, all together:
I have to credit @wgbartley on the idea... I refactored a lot of the code and added:
1: Email alert Icon (changes color based on how many unread in your gmail account, i.e. green yellow, red)
2: temperature display (a little odd in word clock fashion, I admit but you can see hw it displays in the video above.
3: weather "icons" with breathing and lightning effect.... tre cool.
4: some cute special effects that happen on the quarter hours
Here is the total working code if anyone is interested... I had a friend who is a graphic artist do the art, if anyone is interested in the stencil artwork. I haven't completed the build, but the code is there (my code is never "done." I'm always tinkering with new learnings.
SYSTEM_THREAD(ENABLED);
const int pixelCount = 147;
const int breatheRate = 10UL;
const char* cityLocation = "Princeton";  //City for my Photon
const char* stateLocation = "NJ";     // State for my Photon
const int totalEffects = 4;
enum ClockState{
  CLOCK_MODE = 0,
  NIGHT_MODE,
  TEST_MODE,
  WATERFALL_MODE,
  DARK_MODE
enum WeatherState{
  SUNSHINE = 0,
  SNOW,
  PARTLY_CLOUDY,
  LIGHTNING,
  OVERCAST,
  RAIN
struct deviceTime{
  uint8_t Hour;
  uint8_t Minute;
struct colorObject{
  uint8_t red;
  uint8_t green;
  uint8_t blue;
deviceTime sunrise = { 6, 0};
deviceTime sunset  = {18,00};
ClockState currentState = CLOCK_MODE;
ClockState lastState = DARK_MODE;
WeatherState weather_State = PARTLY_CLOUDY;
Adafruit_NeoPixel myPixels = Adafruit_NeoPixel(pixelCount, D2, WS2812B);
const uint8_t word_IT[8] = {0,1};
const uint8_t word_IS[8] = {3,4};
const uint8_t word_FIVE[8] = {26,27,28,29};
const uint8_t word_TEN[8] = {10,11,12};
const uint8_t word_QUARTER[8] = {19,20,21,22,23,24,25};
const uint8_t word_TWENTY[8] = {13,14,15,16,17,18};
const uint8_t word_HALF[8] = {6,7,8,9};
const uint8_t word_MINUTES[8] = {30,31,32,33,34,35,36};
const uint8_t word_PAST[8] = {48,49,50,51};
const uint8_t word_TILL[8] = {37,38};
const uint8_t word_HOUR[13][8] = {
  { NULL, NULL, NULL},       //ZERO NOT USED
  { 44, 45, 46},             //ONE
  { 52, 53, 54},             //TWO
  { 39, 40, 41, 42, 43},     //THREE
  { 56, 57, 58, 59},         //FOUR
  { 61, 62, 63, 64},         //FIVE
  { 75, 76, 77},             //SIX
  { 70, 71, 72, 73, 74},     //SEVEN
  { 65, 66, 67, 68, 69},     //EIGHT
  { 78, 79, 80, 81},         //NINE
  { 82, 83, 84},             //TEN
  { 85, 86, 87, 88, 89, 90}, //ELEVEN
  { 98, 99,100,101,102,103}, //TWELVE
const uint8_t word_OCLOCK[8] = { 91, 92, 93, 94, 95, 96};
const uint8_t word_MESSAGE[8] = {97};
const uint8_t tempCelcius = 104;
const uint8_t tempFahrenheit = 116;
const uint8_t tempNegative = 105;
const uint8_t digit[10] = {115,106,107,108,109,110,111,112,113,114};
const uint8_t pixelRow[9][16] = {
  {0 , 1, 2, 3, 4, 5, 6, 7, 8, 9,10,11,12, NULL},//
  {13,14,15,16,17,18,19,20,21,22,23,24,25, NULL},//
  {26,27,28,29,30,31,32,33,34,35,36,37,38, NULL},//
  {39,40,41,42,43,44,45,46,47,48,49,50,51, NULL},//
  {52,53,54,55,56,57,58,59,60,61,62,63,64, NULL},//
  {65,66,67,68,69,70,71,72,73,74,75,76,77, NULL},//
  {78,79,80,81,82,83,84,85,86,87,88,89,90, NULL},//
  {91,92,93,94,95,96,97,98,99,100,101,102,103, NULL},//
  {104,105,106,107,108,109,110,111,112,113,114,115,116, NULL}//
uint8_t lastMinute = 61U;
bool isMessage = false;
int emailCount = 0;
int lastMailCount = 999;
char responseTopic[125];
char publishString[125];
uint32_t timerToggle= 1;
uint32_t currentWeatherUpdateTime = 0;
uint32_t gmailTime = 0;
char weatherCondition[125] = "Not Yet Reported";
char currentTime[125];
int extTemp = 199;
int celciusTemp = 199;
bool startup = true;
bool isDay;
bool lastTimerCheck;
char daytimeStatus[12] = "Night Time";
void(*displayEffect[totalEffects])();
  displayEffect[0] = waterFallEffect;
  displayEffect[1] = testPanel;
  displayEffect[2] = liteRandomLeds;
  displayEffect[3] = liteEveryLedRandomly;
  sprintf(publishString, "{\"my-city\": \"%s\", \"my-state\": \"%s\" }", cityLocation, stateLocation);
  int timeZoneOffset;
  EEPROM.get(0, timeZoneOffset);
  Time.zone(timeZoneOffset);
  Particle.variable("EmailCount", &emailCount, INT);
  Particle.variable("extTemp", &extTemp, INT);
  //Particle.variable("celcius", &celciusTemp , INT);
  Particle.variable("weather", weatherCondition, STRING);
  Particle.variable("time", currentTime, STRING);
  Particle.variable("dayOrNight", daytimeStatus, STRING);
  Particle.function("mode", setClockMode);
  Particle.function("power", togglePower);
  Particle.function("weather", testWeather);
  String deviceID = System.deviceID();
  deviceID.toCharArray(responseTopic,125);
  Particle.subscribe(responseTopic, webhookHandler, MY_DEVICES);
  myPixels.begin();
  myPixels.clear();
  myPixels.show();
  delay(10000);
  char pushoverMessage[60];
  sprintf(pushoverMessage, "WordClock Restart at %d:%02d%s", Time.hourFormat12(), Time.minute(), Time.isAM()? "am" : "pm");
  Particle.publish("pushover", pushoverMessage, 60, PRIVATE);
  Particle.publish("current_weather", publishString, 60, PRIVATE);
  isDay = timerEvaluate(sunrise.Hour, sunrise.Minute, sunset.Hour, sunset.Minute, Time.minute(), Time.hour(), 0);
  if (isDay != lastTimerCheck)
    if(isDay)
      sprintf(daytimeStatus, "Day Time");
      Particle.publish("pushover", "The sun is now up!", 60, PRIVATE);
    else
      sprintf(daytimeStatus, "Night Time");
      Particle.publish("pushover", "The sun has just set!", 60, PRIVATE);
  lastTimerCheck = isDay;
  sprintf(currentTime, "Current Time: %d:%02d%s, Sunrise: %d:%02d, Sunset: %d:%02d", Time.hourFormat12(), Time.minute(), Time.isAM()? "am" : "pm", sunrise.Hour, sunrise.Minute, sunset.Hour, sunset.Minute);
  if (millis() - gmailTime > 29 * 999UL)
    Particle.publish("browerjames_gmail", publishString, 60, PRIVATE);
    gmailTime = millis();
  if (millis() - currentWeatherUpdateTime > (10 * 60 * 1000UL) || startup)
    startup = false;
    if (timerToggle > 1)
      timerToggle = 0;
    if (timerToggle == 0)
    else if (timerToggle == 1)
      Particle.publish("sun_time", publishString, 60, PRIVATE);
    currentWeatherUpdateTime = millis();
    timerToggle++;
  switch (currentState){
    case (CLOCK_MODE):
      if (currentState != lastState)
        myPixels.clear();
        updateTimePanel(Time.hour(), Time.minute());
      if (emailCount != lastMailCount)
        if (emailCount == 0)
          mailColor = {0,0,0};
          isMessage = false;
          myPixels.setPixelColor(97, myPixels.Color(0, 0, 0));
          myPixels.show();
        else
          if (emailCount < 5)
            mailColor = greenGrass;
          else if (emailCount < 10)
            mailColor = yellowSun;
          else
            mailColor = allRed;
          isMessage = true;
          myPixels.setPixelColor(97, myPixels.Color(mailColor.red, mailColor.green, mailColor.blue));
          myPixels.show();
        switch (weather_State){
          case (SUNSHINE):
            break;
          case (SNOW):
            break;
            break;
          case (OVERCAST):
            break;
          case (LIGHTNING):
            break;
          case (RAIN):
            break;
        displayTemp(extTemp, celciusTemp, 125UL, false);
        int currentTime = Time.now();
        int currentMinute = Time.minute(currentTime);
        int currentSecond = Time.second(currentTime);
        if (currentMinute != lastMinute)
          uint8_t currentHour = Time.hourFormat12(currentTime);
          updateTimePanel(currentHour, currentMinute);
        lastMinute = currentMinute;
      break;
    case (NIGHT_MODE):
        myPixels.clear();
        myPixels.show();
      break;
    case (DARK_MODE):
      liteEveryLedRandomly();
      break;
    case (TEST_MODE):
      testPanel();
      break;
    case (WATERFALL_MODE):
      waterFallEffect();
      break;
  lastState = currentState;
  lastMailCount = emailCount;
void updateTimePanel(uint8_t theHour, uint8_t theMinute)
  static uint8_t priorMinute = 61;
  if (theMinute != priorMinute && (priorMinute == 59 || priorMinute == 14 || priorMinute == 29 || priorMinute == 44))
    uint8_t skitChoice = random(0, 4);
    displayEffect[skitChoice]();
  priorMinute = theMinute;
  clearPixels();
  liteTheWord(word_IT);
  liteTheWord(word_IS);
  if (theMinute < 33)
    liteTheWord(word_HOUR[theHour]);
  else
    if (theHour < 12)
      theHour++;
    else
      theHour = 1;
  if (theMinute < 3)
    liteTheWord(word_OCLOCK);
  else if (theMinute < 8)
    liteTheWord(word_FIVE);
    liteTheWord(word_PAST);
  else if (theMinute < 13)
    liteTheWord(word_TEN);
    liteTheWord(word_MINUTES);
  else if (theMinute < 18)
    liteTheWord(word_QUARTER);
  else if (theMinute < 23)
    liteTheWord(word_TWENTY);
  else if (theMinute < 28)
  else if (theMinute < 33)
    liteTheWord(word_HALF);
  else if (theMinute < 38)
    liteTheWord(word_TILL);
  else if (theMinute < 43)
  else if (theMinute < 48)
  else if (theMinute < 53)
  else if (theMinute < 58)
  else
  myPixels.show();
void clearPixels()
    for(uint8_t i = 0; i < pixelCount; i++)
      myPixels.setPixelColor(i, myPixels.Color(0, 0, 0));
void liteTheWord(const uint8_t * word)
    for(uint8_t i = 0; i < sizeof(word)*2; i++)
      if(isDay)
      else
        timeColor = dullGray;
      myPixels.setPixelColor(word[i], myPixels.Color(timeColor.red, timeColor.green, timeColor.blue));
      direction *= -1;
    myPixels.show();
void displayTemp(const int32_t temp, const int32_t cTemp, uint32_t displayTime, bool celcius)
  colorObject thermocolor;
  if (temp < 41)
    thermocolor = {75,75,255};
  else if (temp > 88)
    thermocolor = {0,255,0};
  else
    thermocolor = {255,255,255};
  uint8_t hundreds = abs(temp % 1000) / 100;
  uint8_t tens = abs(temp % 100) / 10;
  uint8_t ones = abs(temp % 10);
  uint8_t cHundreds = abs(cTemp % 1000) / 100;
  uint8_t cTens = abs(cTemp % 100) / 10;
  uint8_t cOnes = abs(cTemp % 10);
  if(millis() - lastTimeChange < displayTime )
    for(uint8_t i = 104; i <= 116; i++)
    if (hundreds > 0)
      myPixels.setPixelColor(digit[hundreds], myPixels.Color(thermocolor.red, thermocolor.green, thermocolor.blue));
    else if (temp < 0)
      myPixels.setPixelColor(tempNegative, myPixels.Color(thermocolor.red, thermocolor.green, thermocolor.blue));
    myPixels.show();
  else if(millis() - lastTimeChange < displayTime * 3 && abs(temp) > 9)
    myPixels.show();
  else if(millis() - lastTimeChange < displayTime * 4 && abs(temp) > 9)
    myPixels.setPixelColor(digit[tens], myPixels.Color(thermocolor.red, thermocolor.green, thermocolor.blue));
    myPixels.show();
  else if(millis() - lastTimeChange < displayTime * 5)
    myPixels.show();
  else if(millis() - lastTimeChange < displayTime * 6)
    myPixels.setPixelColor(digit[ones], myPixels.Color(thermocolor.red, thermocolor.green, thermocolor.blue));
    myPixels.show();
  else if(millis() - lastTimeChange < displayTime * 7)
    myPixels.show();
  else if(millis() - lastTimeChange < displayTime * 8)
    myPixels.setPixelColor(tempFahrenheit, myPixels.Color(thermocolor.red, thermocolor.green, thermocolor.blue));
    myPixels.show();
  else if(millis() - lastTimeChange < displayTime * 9)
    myPixels.show();
  else if(millis() - lastTimeChange > 10000UL)
    lastTimeChange = millis();
void webhookHandler(const char *event, const char *data)
  if (strstr(event, "browerjames_gmail/0"))
    gotGmailFeed(event, data);
  else if(strstr(event, "current_weather"))
    gotWeather(event, data);
  else if (strstr(event, "sun_time"))
    gotSunTime(event, data);
void gotGmailFeed(const char *event, const char *data)
  String emailReturn = extractString(String(data), "<fullcount>", "</fullcount>");
  if (emailReturn != NULL)
    emailCount = emailReturn.toInt(); //
void gotWeather(const char *event, const char *data)  //  Clear~74.4~86%~NNW~0~70~  <<<<<<< return prototype
  char dataBuffer[125] = "";
  sprintf(dataBuffer, "%s", data);
  char* ptr = strtok(dataBuffer, "\"~");
  sprintf(weatherCondition, "%s", ptr);
  int i = 0;
  while(weatherCondition[i])
    weatherCondition[i] = tolower(weatherCondition[i]);
    i++;
  extTemp = atoi(strtok(NULL, "~"));
  celciusTemp = int((double(extTemp - 32) * (5.0/9.0)));
  if (strstr(weatherCondition, "snow") || strstr(weatherCondition, "ice") || strstr(weatherCondition, "freezing") || strstr(weatherCondition, "sleet"))
    weather_State = SNOW;
  else if (strstr(weatherCondition, "drizzle") || strstr(weatherCondition, "rain"))
    weather_State = RAIN;
  else if (strstr(weatherCondition, "hail") || strstr(weatherCondition, "thunderstorm"))
    weather_State = LIGHTNING;
  else if (strstr(weatherCondition, "overcast"))
    weatherColor = dullGray;
    weather_State = OVERCAST;
  else if (strstr(weatherCondition, "sun") || strstr(weatherCondition, "clear"))
    weatherColor = yellowSun;
    weather_State = SUNSHINE;
  else
void gotSunTime(const char * event, const char * data)
  deviceTime currentTime;
  String sunriseReturn = String(data);
  char sunriseBuffer[25] = "";
  sunriseReturn.toCharArray(sunriseBuffer, 25);
  sunrise.Hour = atoi(strtok(sunriseBuffer, "\"~"));
  sunrise.Minute = atoi(strtok(NULL, "~"));
  sunset.Hour = atoi(strtok(NULL, "~"));
  sunset.Minute = atoi(strtok(NULL, "~"));
  currentTime.Hour = atoi(strtok(NULL, "~"));
  currentTime.Minute = atoi(strtok(NULL, "~"));
  Time.zone(0);
  int currentOffset = getUtcOffset(Time.hour(), currentTime.Hour);
  Time.zone(currentOffset);
  int savedOffset;
  EEPROM.get(0, savedOffset);
  if (currentOffset != savedOffset)
    EEPROM.put(0, currentOffset);
int getUtcOffset(int utcHour, int localHour)  // sorry Baker Island, this won't work for you (UTC-12)
  if (utcHour == localHour)
    return 0;
  else if (utcHour > localHour)
    if (utcHour - localHour >= 12)
      return 24 - utcHour + localHour;
    else
      return localHour - utcHour;
  else
    if (localHour - utcHour > 12)
      return  localHour - 24 - utcHour;
    else
String extractString(String myString, const char* start, const char* end)
  if (myString == NULL)
    return NULL;
  int index = myString.indexOf(start);
  if (index < 0) {
    return NULL;
  int endIdx = myString.indexOf(end);
  if (endIdx < 0) {
    return NULL;
  return myString.substring(index + strlen(start), endIdx);
void testPanel()
  for(int j = 0; j < 3; j++)
    for (int i = 0; i < pixelCount; i++)
      if (i == 0)
        myPixels.setPixelColor(pixelCount-1, myPixels.Color(0, 0, 0));
      myPixels.setPixelColor(i-1, myPixels.Color(0, 0, 0));
      myPixels.setPixelColor(i, myPixels.Color(j % 3 == 0? 255: 0, j % 3 == 1? 255: 0,  j % 3 == 2? 255: 0));
      myPixels.show();
      Particle.process();
      delay(10);
void waterFallEffect()
  for (uint8_t pass = 0; pass < 3; pass++)
    for (uint8_t row = 0; row < 9; row++)
      for(uint8_t pixel = 0; pixel < 16; pixel++)
        if (pixelRow[row][pixel] == NULL && (row != 0 && pixel != 0)) break;
        myPixels.setPixelColor(pixelRow[row][pixel], myPixels.Color(pass %3 == 0 ? 255 : 0, pass % 3 == 1 ? 255 : 0, pass % 3 == 2 ? 255 : 0));
      myPixels.show();
      delay(50);
      for (uint8_t k = 0; k <= 116; k++)
        myPixels.setPixelColor(k, myPixels.Color(0, 0, 0));
        if (pixelRow[row][pixel] == NULL /*&& (9 - row != 0 && pixel != 0)*/) break;
        myPixels.setPixelColor(pixelRow[9 - row][pixel], myPixels.Color(pass %3 == 0 ? 255 : 0, pass % 3 == 1 ? 255 : 0, pass % 3 == 2 ? 255 : 0));
      myPixels.show();
      Particle.process();
      delay(50);
void liteRandomLeds()
  for(int j = 0; j < 100; j++)
    clearPixels();
    uint8_t color = random(0,3);
    myPixels.setPixelColor(random(0,pixelCount), myPixels.Color(color % 3 == 0? 255: 0, color % 3 == 1? 255: 0,  color % 3 == 2? 255: 0));
    myPixels.show();
    Particle.process();
    delay(20);
void liteEveryLedRandomly()
  uint8_t randomArray[pixelCount];
  for (uint8_t i = 0; i < pixelCount; i++)
    randomArray[i] = i;
    randomSeed(analogRead(A0));
    uint8_t location = random(i, pixelCount);
    uint8_t value = randomArray[location];
    randomArray[location] = randomArray[i];
    randomArray[i] = value;
  for (uint8_t i = 0; i < 3; i++)
    for (uint8_t j = 0; j < pixelCount; j++)
      myPixels.clear();
      myPixels.setPixelColor(randomArray[j], myPixels.Color(color == 0? 255: 0, color == 1? 255: 0,  color == 2? 255: 0));
      myPixels.show();
      Particle.process();
      delay(25);
int setClockMode(String command)
  char myCommand[125] = "";
  command.toCharArray(myCommand,125);
  int i = 0;
  while(command[i])
    command[i] = tolower(command[i]);
    i++;
  if (strstr(command, "clock"))
  else if (strstr(command, "night"))
    currentState = NIGHT_MODE;
  else if (strstr(command, "test"))
    currentState = TEST_MODE;
  else if (strstr(command, "waterfall"))
    currentState = WATERFALL_MODE;
  else if (strstr(command, "dark"))
    currentState = DARK_MODE;
  return 1;
int togglePower(String command)
  int value = command.toInt();
  if (value == 0)
  else if (value == 1)
  else if (value == 2)
    currentState = currentState == CLOCK_MODE? DARK_MODE : CLOCK_MODE;
  char pushoverMessage[60] = "";
  sprintf(pushoverMessage, "WordClock is now %s", (currentState == CLOCK_MODE? "ON" : "OFF"));
  Particle.publish("pushover", pushoverMessage, 60, PRIVATE); // Spark WebHook!!!
  return currentState == CLOCK_MODE? 1: 0;
int testWeather(String command)
  int i = 0;
  while(command[i])
    i++;
  if (strstr(myCommand, "sunshine"))
    return 0;
  else if (strstr(myCommand,"snow"))
    return 0;
  else if (strstr(myCommand, "partly"))
    return 0;
  else if (strstr(myCommand, "lightning"))
    return 0;
  else if (strstr(myCommand, "overcast"))
    return 0;
  else
    return 1;
bool timerEvaluate(int start_Hour, int start_Minute, int end_Hour, int end_Minute, int now_Minute, int now_hour, int now_second)
  int start_time = tmConvert_t(Time.year(), Time.month(), Time.day(), start_Hour, start_Minute, 0);
  int end_time = tmConvert_t(Time.year(), Time.month(), Time.day(), end_Hour, end_Minute, 0);
  int now_time = tmConvert_t(Time.year(), Time.month(), Time.day(), now_hour, now_Minute, now_second);
  if (start_time < end_time)
    return (now_time > start_time && now_time < end_time);
  else if (end_time < start_time)
    return (now_time < end_time || now_time > start_time);
  else
    return false;
time_t tmConvert_t(int YYYY, byte MM, byte DD, byte hh, byte mm, byte ss)
  struct tm t;
  t.tm_year = YYYY-1900;
  t.tm_mon = MM - 1;
  t.tm_mday = DD;
  t.tm_hour = hh;
  t.tm_min = mm;
  t.tm_sec = ss;
  t.tm_isdst = 0;
  time_t t_of_day = mktime(&t);
  return t_of_day;
Original Project:
stencil:
Great share @BulldogLowell, thanks! I’ll create a project share when i\m done with mine :slight_smile: (Not a world clock btw)
great, some new inspiration!
PS: everyone has to have their own version of a word clock, it is a rite of passage. I forgot to mention that my son's name is hidden in the stencil, my final firmware types his name on his birthday... see it... Jules!
I hope I passed mine then :wink:
Still want to use a 64x32 panel to make a 32x16 combined clock/weather/calendar version though... In case anyone needed more ideas :wink:
Why wait? :smiley:
Exams, and lack of a laser cutter :confused: Also, I still quite like my Death Star one, so I’m in no rush :innocent:
Nice work! Thanks for pinging me on this. I love the weather icons. The flashing lightning was a brilliant touch! Do you have a larger or vector version that I could steal? I’d love to make a small weather display with just the icons.
The original art is 20in x 20in so you may be OK with the size.
I’ll throw it all up on github later this weekend.
@wgbartley,
As promised (but a little later) I posted the artwork to my github Weather-Word-Clock.
Posted in a PDF, it was all I had. I had a third party cut the stencil…
I’ll copy this link to your original post…
Thanks! Better late than never! I was actually playing around with converting PDFs to SVGs in Inkscape this weekend, so I have another tool on my belt.
Which font did you use? Is it fixed-width (it certainly looks like it)? I’ve been using one called “ModeNine”.
Have you looked into CSS SVG icons? Considering they’re used abundantly in web design, there are plenty floating around for free. Something like this: http://www.flaticon.com/search?word=Weather&color=1
