Soil Sensor - I²C Capacitive Moisture Sensor
I have a Adafruit Soil Sensor - I²C Capacitive Moisture Sensor
The Capacitive value should be between 0 and 2000
I am getting the correct measurement on my seeed xiao.
Does anyone see anything in the code below that would be causing this reading issue with particle?
#include "Adafruit_Seesaw.h"
Adafruit_Seesaw ss;
  Serial.begin(115200);
  while (!Serial)
    delay(10);
  Serial.println("seesaw Soil Sensor example!");
  if (!ss.begin(0x36))
    Serial.println("ERROR! seesaw not found");
    while (1)
  else
    Serial.print("seesaw started! version: ");
    Serial.println(ss.getVersion(), HEX);
int last_x = 0, last_y = 0;
  uint16_t tempC = ss.getTemp();
  uint16_t capread = ss.touchRead();
  Serial.print("Temperature: ");
  Serial.print(tempC);
  Serial.println("*C");
  Serial.print("Capacitive: ");
  Serial.println(capread);
  delay(100);
below is the serial monitor results
Capacitive: 65535
Temperature: 26*C
Link to sensor –
Adafruit STEMMA Soil Sensor - I2C Capacitive Moisture Sensor : ID 4026 : $7.50 : Adafruit Industries, Unique & fun DIY electronics and kits
@bbarr7iot, tempC is declared as an uint16_t but the getTemp() function returns a float. Change the declaration and try it again to see if it works or at least what value is “truly” returned.
I got it working with the code below, can you update the library when searching for seesaw.
https://go.particle.io/shared_apps/6169c0afde87cd0008e33f74
@bbarr7iot, what did you change to get it working?
Did you need Adafruit_I2CDevice library if you didn’t call it?
Did you alter the Adafruit_Seesaw library?
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
