Setup.particle.io - selecting a Device OS
When using setup.particle.io for a Photon, the default OS installed is 3.3.1. Is there any way to modify this Device OS version - say to 2.3.1?
It is not possible to change the Device OS version.
However, setup.particle.io is only intended for setting up individual developer devices; there are a number of other tools for onboarding device fleets that do allow the version to be set.
Hi, that is a bit dated version of DeviceOS, what device is this? Just curious
Photon
Which tools?
If you already have the firmware you want, you can just use the Particle CLI. Just pass the Device OS version you want as --target
particle usb dfu
particle flash --local --target 2.3.1 firmware.bin
