I am trying to setup a xenon with the Ethernet base as a gateway. the app scans the QR code and links, but then I cannot get past the scanning for mesh networks screen. The xenon is plugged into the Ethernet base and lan connected… Any idea?
On one of the screens before you scan the device barcode, there is a slider at the bottom of the screen to enable the Ethernet functionality. Note, when you enable Ethernet, the Xenon becomes a gateway and you have to create a new mesh network. You cannot add a gateway Xenon to an existing mesh network yet.
