I am not able to get the container (https://hub.docker.com/r/particle/buildpack-particle-firmware/) up and running. What version should I be using?
Errors:
USER$ export PROJECT_DIR=/Users/User/Desktop/file
USER$ export PLATFORM_ID=6
USER$ export VERSION=0.4.5
USER$ docker run --rm \
> -v $PROJECT_DIR:/input \
> -v $PROJECT_DIR:/output \
> -e PLATFORM_ID=$PLATFORM_ID \
> particle/buildpack-particle-firmware:$VERSION
Unable to find image 'particle/buildpack-particle-firmware:0.4.5' locally
docker: Error response from daemon: manifest for particle/buildpack-particle-firmware:0.4.5 not found.
See 'docker run --help'.
USER$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
USER$ docker ps -a
USER$ docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
particle/buildpack-particle-firmware latest f8acaef9361d 2 days ago 735MB
USER$ docker pull particle/buildpack-particle-firmware:0.4.5
Using default tag: latest
latest: Pulling from particle/buildpack-particle-firmware
Digest: sha256:12f1546eeeb672a7948720ea949e33eee2a301c177d886338be493c6f28b9f60
Status: Image is up to date for particle/buildpack-particle-firmware:latest
