Set string values using an Android App
Hey,
I’m new this so it may be a stupid question but is there a way to pass string values to the photon using a mobile app and save them on the particle.
I want customers to setup the particle and specify what phone number and message they would like to receive when a event is triggered.
I want to automate this process.
This will be the functions you want to investivate first for the device side
https://docs.particle.io/reference/device-os/firmware/photon/#particle-function-
https://docs.particle.io/reference/device-os/firmware/photon/#particle-subscribe-
And here is the link for the Android side
https://docs.particle.io/reference/SDKs/android/
in particular
https://docs.particle.io/reference/SDKs/android/#call-a-function
https://docs.particle.io/reference/SDKs/android/#publishing-an-event
Thanks @ScruffR
Does the Particle.function() save the received value so after the device reboots it knows what was the last value?
Have a look: https://docs.particle.io/reference/device-os/firmware/photon/#eeprom
No it doesn't, hence you need to store the data either in EEPROM as Moors7 already mentioned or if you only mean a reset/deep sleep without actuall loss of power you could get away with Backup RAM
But EEPROM would be the best way to go for configuration data.
