Saving String to EEPROM
I’m trying to save a String value that is being passed from a function to the EEPROM.
The code below works if I define myObj as below but will not work if I pass a String Value I get error
invalid user-defined conversion from ‘String’ to ‘char’ [-fpermissive]
This works:
MyObject myObj = {
    "someValue"
This does not:
SYSTEM_THREAD(ENABLED);
int pin = D4;
int led1 = D7;
int state;
int setPhoneEEPROMLocation = 1;
char email[20];
String setPhoneString;
struct MyObject {
  char phoneNumber[20];
  getStoredInfo();
  pinMode(pin, INPUT_PULLUP);
  pinMode(led1, OUTPUT);
  if (digitalRead(pin) == LOW) {
    digitalWrite(led1, HIGH);
    Particle.publish("DoorStatus", "OPEN", 60, PRIVATE);
  } else {
    Particle.publish("DoorStatus", "CLOSED", 60, PRIVATE);
  Particle.variable("Status", state);
  Particle.variable("Phone", setPhoneString);
  Particle.function("setPhone", setPhone);
  for (uint32_t ms = millis(); millis() - ms < 200; Particle.process());
    if (state != 0) {
      state = 0;
  } else if (digitalRead(pin) == HIGH) {
    if (state != 1) {
      digitalWrite(led1, LOW);
      state = 1;
int setPhone(String phoneNumber) {
  setPhoneString = phoneNumber;
  Particle.publish("set", setPhoneString);
  MyObject myObj = {
    setPhoneString
  EEPROM.put(setPhoneEEPROMLocation, myObj);
void getStoredInfo() {
  MyObject myObj;
  EEPROM.get(setPhoneEEPROMLocation, myObj);
  setPhoneString = (myObj.phoneNumber);
Not sure if this is the right approach but for anyone interested below is the working code
int pin = D4;
int led1 = D7;
int state;
char email[20];
char phoneNumber[50];
  getStoredInfo();
  } else {
    if (state != 0) {
      state = 0;
    if (state != 1) {
      state = 1;
int setPhone(const char * data) {
  setPhoneString = data;
  strncpy(phoneNumber, data, sizeof(phoneNumber) - 1);
  phoneNumber[sizeof(phoneNumber) - 1] = '\0';
  EEPROM.put(setPhoneEEPROMLocation, phoneNumber);
  EEPROM.get(setPhoneEEPROMLocation, phoneNumber);
Thanks for this. I think i found one of my problems.
