Storing JSON Sting in Photon's Eprom
I want to store simple JSON string, {“name”: “particle”, “data”: “1,2,3,4”}. Please let me know what is the best way to go about without having to parse and do memory mapping.
Thanks.
creating a struct would be one approach:
struct MyDATA{
  char deviceID[25];
  byte data[4];
store:
MyDATA info = {"53ba42000b5135fe35321335", 1, 2, 3, 4};
EEPROM.put(0 * sizeof(MyDATA), info)
and get it:
MyDATA buffer = EEPROM.get(0 * sizeof(MyDATA));
char jsonText[128] = "";
snprintf(jsonText, sizeof(jsonText), "{\"name\":\"%s\",\"data\":\"%d,%d,%d,%d\"}", buffer.deviceID, buffer.data[0], buffer.data[1], buffer.data[2], buffer.data[3]);
Serial.println(jsonText);
something like that…
thanks.
@BulldogLowell, I just tried your code. I am getting the following compile error on this line:
EEPROMClass::get(unsigned int)
@BulldogLowell, thanks. Never mind, I got the fixed.
@BulldogLowell, I am getting invalid user-defined conversion from ‘String’ to ‘char’ [-fpermissive] when I do this Particle function call below:
int storeJSON(String args){
MyDATA info ={args}; //(error at this line)
EEPROM.put(0 * sizeof(MyDATA), info);
return 1;
I was using this code months back. Now, I cannot compile it. Please help.
Why do you have args wrapped in curly braces in your function?
This is C++, not JavaScript!
:slight_smile:
@BulldogLowell; I figured it out. I had to do strcpy(xxx,"");. Thanks anyway.
