Servo Issue: Noobie question
Hi, I had a servo working on my Spark Core a few years ago, I just replaced it with a Photon and cannot get the servo to work.
The LED blinks perfectly but the servo doesn’t move. I have it attached to A0, 3v and GND as I had with Spark Core.
Below is my code snippet.
Any idea?
Thanks.
Phil
Servo myservo;
int pos = 0;
int startPos=45;
int endPos = 125;
bool swinging = false;
int queue = 0;
 pinMode(D7, OUTPUT); // sets the pin as output
//  Spark.function("kitty", swingArm);
     digitalWrite(D7, HIGH); // LED on
     myservo.attach(A0);
     myservo.write(endPos);
     delay(300);
     myservo.write(startPos);
     delay(1000);
     myservo.detach();
     digitalWrite(D7, LOW); // LED off
     delay (5000);
For a servo you need a PWM capable pin, A0 is not one of them on the Photon
See docs (which should be consulted first ;-))
https://docs.particle.io/reference/firmware/photon/#analogwrite-pwm-
Wow… thanks for such a quick reply… I had no idea that the pins were different.
I checked that the actual pinouts were the same but not the PMW…
Much appreciated.
Phil
