Newbie help - photon
Hi there,
I have purchased a Photon board and have used some copied code from the Particle site to try and gain full analogy control of the position of a servo.
I have a device ID and access token and the code is flashed to the chip.
How can I use that code (its currently flashed to the chip in an app called servo)?
Without tinker on the chip any more the mobile phone control app doesn’t work. I know this is probably a really dumb question but I basically have no programming experienced.
My main goal is to have a servo that i can control the position of remotely.
It has a 180 degree range and id like to be able to move it to set positions 0 90 and 180.
Any help/advice/answers would be great.
Have you seen this tutorial I wrote on exactly this topic yet?
