Send an integer/float variable from particle cloud to photon
i need to set a variable from particle cloud console and send it to the photon throught the particle cloud. the variable is a float or integer and i need to use this variable in the loop for some calculation.
now i’m able to read read variable in the cloud from photon using “particle.variable()” but i can’t understand how to set a variable in the cloud and send it to the firmware loop that run in the photon
thank you
Have a look:
A Particle variable can not be of type “float”. Only int, double, and string are permitted. Here is an example using a double:
  double Double = 0;
    Particle.function("setDouble", setDouble);
    Particle.variable("Double", Double);
int setDouble(String s) {
    Double = atof(s);
The variable “Double” is a global variable, and can be referenced in loop().
Note: atof() actually returns a double.
Your setDouble() should return an int as result code.
thank you all!
now i’m able to set a variable from the clud and make it run in to the loop
bye
carlo
