selectMeshAntenna bug on Xenon
After suffering a few range problems, I have tried adding an external antenna to a Xenon, and using the following function to pick which antenna is used:
int setAntenna(int i) {
    // Save to EEPROM
    EEPROM.put(antAddr, i);
    if(i==0) {
        Mesh.selectAntenna(MeshAntennaType::INTERNAL);
    } else {
        Mesh.selectAntenna(MeshAntennaType::EXTERNAL);
This gives the following error on all 1.5.x firmwares when compiling from the webIDE, including the 1.5.4-rc.1:
In file included from ./inc/Arduino.h:27:0,
                 from ./inc/WProgram.h:1,
                 from lib/Adafruit_BME280/src/Adafruit_BME280.h:27,
                 from solar_soil_sensor.ino:65:
solar_soil_sensor.ino: In function 'int setAntenna(int)':
../wiring/inc/spark_wiring_arduino_constants.h:44:21: error: expected unqualified-id before numeric constant
 #define EXTERNAL    0
solar_soil_sensor.ino:282:45: note: in expansion of macro 'EXTERNAL'
solar_soil_sensor.ino:284:1: warning: no return statement in function returning non-void [-Wreturn-type]
../build/module.mk:274: recipe for target '../build/target/user/platform-14-msrc/solar_soil_sensor.o' failed
make[2]: *** [../build/target/user/platform-14-msrc/solar_soil_sensor.o] Error 1
Can I get away with just doing:
Mesh.selectAntenna(0);
to use the external antenna?
I had a look at some of the code people have posted here, to test if my RSSI changes, but if I can be sure the antenna changes then greater reliability is enough to show an improvement.
That is happening due to another definition of EXTERNAL.
If you add #undef EXTERNAL at the top of your code it should work.
Thanks, that has done the trick. It looks like the other def was being added by one of the sensor libraries I’m using, so I put the #undef after the #includes.
