Hi everyone
Been trying to get this to work but following errors found
Any suggestions appreciated, thinking of taking fishing up instead…
Hi everyone
For error : redeclaration of ‘NO_ERROR’ - try changing the NO_ERROR to ERROR_NONE in the enum and where used in the .h file. I am guessing that NO_ERROR is already used in Arduino.h or Wire.h.
Try rebuilding, if you still get the line 63 error: conflicting declaration then try changing the type name to error_t. Clearly you will also need to change occurrences of err_t to error_t.
Alternatively, you could try replacing #include “Arduino.h” and “Wire.h” with “Particle.h”? Sometimes things require the “Arduino.h” to build sometimes not and that might remove the conflict.
Thanks armor,
I’ll give it a try.
I have seen a reference on adafruit that the issue could be related to nRF52 incompatibility.
So may be in real trouble!
It should work if just an I2C device. Maybe need to re-write the driver software.
Hi armor
ERROR_NONE worked
error_t worked
i removed the “}err_t;” from below ERROR_OTHERS
So compiled i now get this
Many thanks
When you hit the SHOW RAW button you may get more info about the possible reasons for that error message.
(also showing that message - with its context - can help people round here)
However, I’d advise against using byte as a parameter name as it may well be used as a data type too (which would explain the error message)
Hi ScruffR
This is the RAW
Processing iwseeedpstrial.ino
make -C ../modules/boron/user-part all
make[1]: Entering directory '/firmware/modules/boron/user-part'
mkdir -p target/
make -f ../../../modules/shared/nRF52840/build_linker_script.mk PREBUILD=1
make[2]: Entering directory '/firmware/modules/boron/user-part'
Creating target/platform_user_ram.ld ...
make[2]: Leaving directory '/firmware/modules/boron/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: Seeed_HM330X.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-13-m
arm-none-eabi-gcc -DSTM32_DEVICE -DnRF52840 -DNRF52840_XXAA -DPLATFORM_THREADING=1 -DPLATFORM_ID=13 -DPLATFORM_NAME=boron -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD00D -DUSBD_PID_CDC=0xC00D -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DINCLUDE_PLATFORM=1 -DSOFTDEVICE_PRESENT=1 -DS140 -DPRODUCT_ID=13 -DPRODUCT_FIRMWARE_VERSION=65535 -DOPENTHREAD_PROJECT_CORE_CONFIG_FILE=\"openthread-config-project.h\" -DENABLE_FEM=1 -DNRF_802154_PROJECT_CONFIG=\"openthread-platform-config.h\" -DRAAL_SOFTDEVICE=1 -D_WIZCHIP_=W5500 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DLFS_CONFIG=lfs_config.h -DSYSTEM_VERSION_STRING=1.4.0 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/boron -I../hal/network/lwip/ublox -I../hal/src/nRF52840 -I../hal/src/armv7 -I../hal/src/nRF52840 -I../hal/src/nRF52840/lwip -I../hal/src/nRF52840/freertos -I../hal/src/nRF52840/openthread -I../hal/src/nRF52840/mbedtls -I../hal/src/nRF52840/littlefs -I../hal/network/api -I../hal/network/lwip -I../hal/network/lwip/posix -I../hal/network/openthread -I../hal/network/lwip/wiznet -I../hal/network/ncp -I../hal/network/ncp/at_parser -I../third_party/lwip/lwip/src/include -I../third_party/freertos/freertos/FreeRTOS/Source/include -I../third_party/nrf5_sdk/nrf5_sdk/external/freertos/portable/GCC/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/external/freertos/portable/CMSIS/nrf52 -I../third_party/openthread/openthread/include -I../third_party/openthread/openthread/src/core -I../third_party/openthread/openthread/examples/platforms -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio/hal -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio/rsch -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio/rsch/raal -I../third_party/openthread/openthread/third_party/NordicSemiconductor/drivers/radio/rsch/raal/softdevice -I../third_party/wiznet_driver/wiznet_driver/Ethernet -I../gsm0710muxer/gsm0710muxer/include -I../platform/shared/inc -I../third_party/nrf5_sdk -I../third_party/nrf5_sdk/nrf5_sdk/components/toolchain/cmsis/include -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers/include -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/hal -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/mdk -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/hal -I../third_party/nrf5_sdk/nrf5_sdk/modules/nrfx/drivers/src/prs -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/util -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/common -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fstorage -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_section_vars -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/crc32 -I../third_party/nrf5_sdk/nrf5_sdk/integration/nrfx/legacy -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/delay -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/log -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/log -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/log/src -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/experimental_section_vars -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/delay -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/queue -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/common -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/mbr/nrf52840/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140 -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers -I../third_party/nrf5_sdk/nrf5_sdk/components/softdevice/s140/headers/nrf52 -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fifo -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic_fifo -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/strerror -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/fstorage -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/atomic_flags -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd/class/cdc -I../third_party/nrf5_sdk/nrf5_sdk/components/libraries/usbd/class/cdc/acm -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/common -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/nrf_ble_gatt -I../third_party/nrf5_sdk/nrf5_sdk/components/ble/ble_advertising -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/t2t_lib -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/platform -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/generic/message -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/generic/record -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/lauchapp -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/text -I../third_party/nrf5_sdk/nrf5_sdk/components/nfc/ndef/uri -I../third_party/nrf5_sdk/nrf5_sdk/external/nrf_cc310/include -I../third_party/nrf5_sdk/nrf5_sdk/external/utf_converter -I../third_party/littlefs/littlefs -I../platform/MCU/nRF52840/inc -I../dynalib/inc -I -I./libraries -I. -MD -MP -MF ../build/target/user/platform-13-mSeeed_HM330X.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DSPARK_PLATFORM_NET=UBLOXSARA -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0xD4000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,1,1401 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\"" -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-13-mSeeed_HM330X.o Seeed_HM330X.cpp
In file included from Seeed_HM330X.cpp:32:0:
Seeed_HM330X.h:82:1: error: multiple types in one declaration
Seeed_HM330X.h:82:1: warning: 'typedef' was ignored in this declaration
Seeed_HM330X.cpp: In member function 'error_t HM330X::init()':
Seeed_HM330X.h:38:38: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
#define CHECK_RESULT(a,b) do{if(a=b) { \
Seeed_HM330X.cpp:50:5: note: in expansion of macro 'CHECK_RESULT'
CHECK_RESULT(ret,select_comm());
Seeed_HM330X.cpp: In member function 'error_t HM330X::read_sensor_value(u8*, u32)':
Seeed_HM330X.cpp:59:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
while(data_len!=Wire.available())
Seeed_HM330X.cpp:65:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for(int i=0;i<data_len;i++)
Seeed_HM330X.cpp: In member function 'error_t IIC_OPRTS::IIC_read_byte(u8, u8*)':
Seeed_HM330X.cpp:136:13: warning: unused variable 'ret' [-Wunused-variable]
error_t ret=ERROR_NONE;
Seeed_HM330X.cpp: In member function 'error_t IIC_OPRTS::IIC_read_16bit(u8, u16*)':
Seeed_HM330X.cpp:160:13: warning: unused variable 'ret' [-Wunused-variable]
Seeed_HM330X.cpp: In member function 'error_t IIC_OPRTS::IIC_read_bytes(u8, u8*, u32)':
Seeed_HM330X.cpp:198:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Seeed_HM330X.cpp:205:18: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
../build/module.mk:277: recipe for target '../build/target/user/platform-13-mSeeed_HM330X.o' failed
make[2]: *** [../build/target/user/platform-13-mSeeed_HM330X.o] Error 1
make[2]: Leaving directory '/firmware/user'
../../../build/recurse.mk:11: recipe for target 'user' failed
make[1]: *** [user] Error 2
make[1]: Leaving directory '/firmware/modules/boron/user-part'
../build/recurse.mk:11: recipe for target 'modules/boron/user-part' failed
make: *** [modules/boron/user-part] Error 2
Have you tried substituting byte with somethinge else which isn’t also a data type?
No, but I will try that
Cheers
If that doesn’t work you can post a SHARE THIS REVISION link here to allow others to compile your code.
Thanks for that, steep learning curve at the moment!!
In your attempt to solve the error_t issue you have also commented out the terminating semicolon for that enum in line 64 (which we couldn’t see in your screenshot
fat fingers, ive also just realised that i’ve connected a PMS5003 straight up to 6v. I was wondered why it had packed up!!!
If you actually want to use your local typedef for error_t you’d have to give it a name and then also use that everywhere in your code.
I’ve quickly corrected the errors I could find
https://go.particle.io/shared_apps/5da5f89931209b000a0b95d5
You can COPY THIS APP and see for yourself.
Can you report back once you have copied this so that I can remove it from my account again?
Wow, what can I say apart from thanks so much!!
I will test as soon as I can.
Cheers
I just realised there are some other instances where error_t needed replacing
https://go.particle.io/shared_apps/5da5fdaf31209b00050b9714
Again, many, many thanks.
I have just found an easier sketch for me to handle but it still needs the .h so …
Cheers
Report is most excellent. Really quick and responsive sensor.
Just need to pick out the particle.publish info…
@davo101 is it possible to post this final project with the seeed HM3301 fully working?
