Where did you get that code from?
What are you trying to do?
Which IDE are you using?
How are you including those files?
Where did you make the mentioned change?
What’s the actual error output?
You didn't answer the single most important question
And the prefered way is #include "Particle.h" instead of #include "application.h"
But in .ino files you'll not need it anyway so just removing #include "Wire.h" should suffice.
power.cpp:3:37: error: 'word' has not been declared
static void writeRegister(byte reg, word value);
power.cpp:5:8: error: 'word' does not name a type
static word readRegister(byte reg);
power.cpp:7:7: error: 'word' does not name a type
void setup();
power.cpp:65:37: error: 'word' has not been declared
#define INA226_CONF_AVG_256 (5<<9) // 256
power.cpp: In function 'void setupRegister()':
power.cpp:84:41: error: 'INA226_CAL_VALUE' was not declared in this scope
power.cpp: At global scope:
power.cpp:87:8: error: 'word' does not name a type
| INA226_CONF_MODE_CONT_SHUNT_AND_BUS
power.cpp:125:10: error: 'word' does not name a type
{ INA226_REG_MASK_ENABLE, "Mask/Enable" },
power.cpp:128:25: error: 'REGS' was not declared in this scope
power.cpp:4:29: note: in definition of macro 'NELEMS'
static void setupRegister(void);
power.cpp:130:38: error: 'readRegister' was not declared in this scope
static void dumpRegisters(void)
power.cpp:135:25: error: 'REGS' was not declared in this scope
static char buf[64];
power.cpp: In function 'void loop()':
power.cpp:158:63: error: 'readRegister' was not declared in this scope
make[1]: *** [../build/target/user/platform-6power.o] Error 1
make: *** [user] Error 2
Error: Could not compile. Please review your code.
