I would like to kill two birds with one stone. I would like to set up a local Blynk server, and run a Blynk sketch at the same time on the same pi. The Blynk sketch would thus connect to the server on the same IP address. Has anyone done that already? Does that work?
That sounds like it should work. Have you tried it yet?
Hi, I would like to run a sketch using the Blynk library on a raspberry pI. Has anyone done that successfully?
@hbierau, perhaps you should be asking this on the Blynk forum?
