Photon-code does not work on Blynk local server
Hello everybody,
I have got the following code working with the online Blynk-server:
#define BLYNK_PRINT Serial
#include <blynk.h>
char auth[] = "xxxxxxxxxxxxxxxxx";
int pinValue;
BLYNK_WRITE(V1)
  pinValue = param.asInt();
  delay(5000);
  Blynk.begin(auth);
  pinMode(D7, OUTPUT);
  Blynk.run();
  if (pinValue==1)
  {digitalWrite(D7, HIGH);
  else
  {digitalWrite(D7, LOW);
When I use the same code for the Blynk local server it doesn’t work:
#include <blynk.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxx";
int pinValue;
BLYNK_WRITE(V1)
  delay(5000);
  Blynk.begin(auth, IPAddress(192,168,0,101), 8080);
  Blynk.run();
  if (pinValue==1)
  else
I can access my Blynk local server so there is no problem with IP-address. My Blynk local server is also running the latest version and authorisation-code is correct.
Anybody an idea what could be wrong? Thanks in advance,
Bart
This question would be best raised with the Blynk community and/or file an issue on the Blynk library repo.
