Hey all,
I currently have about 20 particles that I am trying to connect to the same WLAN for a project installing next week. I have been developing the code on one device at a time and finally received enough to start doing larger scale tests.
I am running the exact same code on 7 boards (only difference being the ip address assigned) and only two of them are able to connect to the network.
In my main am running this to connect:
networks.config_creds( SSID, PW );
Serial.println("creds configured");
networks.config_static_ip();
Serial.println("static ip configured...connecting");
networks.connect();
In the networks class I am running this:
// Connect to WiFi Network
WiFi.connect(WIFI_CONNECT_SKIP_LISTEN);
delay(1000);
while(!WiFi.ready())
Particle.process();
Serial.println("Waiting on Network");
if(WiFi.ready())
Serial.println("Connected to:");
Serial.println(WiFi.SSID());
Serial.println("---");
Serial.print("deviceID: ");
String myID = System.deviceID();
Serial.println(myID);
Serial.printlnf("System version: %s", System.version().c_str());
uint32_t freemem = System.freeMemory();
Serial.print("free memory: ");
Serial.println(freemem);
I have tried two different routers, to no avail. I am able to open up a serial port and see it print statements showing it’s looking for the network, although if I try particle identify I get a serial timeout error.
Any advice or where to start troubleshooting would much appreciate!
