Hello, i’m trying to figure out how to use this Sainsmart TGS2600 i purchased from here: https://www.sainsmart.com/products/air-contaminants-sensor-tgs2600
Anyways, I have tried setting it up in several different ways and im not entirely sure what to do or how to understand anything it outputs. I have sent Sainsmart tech support a lot of emails without any help, and have only seen datasheets for the TGS, but not the breakout board with it.
Does ANYBODY have any basic test code or schematics i could reference for better understanding?
here is the datasheet:
http://www.figarosensor.com/products/2600pdf.pdf
there are larger ones with more information i can provide if necessary.
Here are a few github projects i have looked through and havent deciphered very well:
Thank you for your time if you made it this far.
If you would like for me to produce what i have written in code, i can do that as well, however it isnt much
